Old 03-23-2007, 03:35 PM   #1
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Your welcome
Here is a battery that is under 7 lbs . and carbon fiber none the less . BAD ASS :)
www.braillebatteries.com
just one of my secrets .........
I gutted my stock battery and put this battery in the shell :) for a savings of about 25 lbs
Old 03-23-2007, 03:53 PM   #2
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
cheez them battery is expensive
jamal1984 is offline   Reply With Quote
Old 03-23-2007, 05:45 PM   #3
bigsky2
Cousin Vitz
bigsky2's Avatar
You're welcome.
Old 03-23-2007, 08:02 PM   #4
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
I was going to go with Odyssey batteries - cheaper but not quite the same amp ratings.
anyone interested
http://www.odysseyfactory.com/specs.htm
this one in particular PC625
At a show here a month or so ago they priced this battery at $120 can.
mikeukrainetz is offline   Reply With Quote
Old 03-24-2007, 04:14 AM   #5
the 7 lb one wouldn't be fit for daily driving usage, right?
Old 03-24-2007, 01:27 PM   #6
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Kinetik batteries are another good choice as well.
― Thomas Paine
Old 03-24-2007, 02:45 PM   #7
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Replace those every year, or you will be sorry. Even more often in colder climates. I've seen alot of those die. If you have upgraded your stereo or anything don't even bother. I've also seen them cause many tuning problems on higher powered cars.
