Old 05-02-2013, 12:00 AM   #1
MaXx0909
Drives: Toyota Yaris 07 hatchback
Exhaust manifold heat shield Problems. Help!!
Alright, so i have 138k kms on my yaris, everything is fine, except that squeaky shifter and those rattles.A while ago, my heat shield starting tapping on the exhaust manifold (no big deal just annoying) but now , i am pretty sure i got an exhaust leak on my manifold somewheres as every time I step on the gas in second and + gear, it makes this noise like if there's air coming out. My concern is , could it be that these two what seems to be bolts, are done and are letting air come out ?
Thanks for the help y'alll
(yes i am aware its rusty and dirty, but i live in canada so salt dosnt help and i get it sprayed with oil before winter so it dosnt rusts and become more orange than the car itself)
MaXx0909 is offline   Reply With Quote
Old 05-02-2013, 12:26 AM   #2
It is more likely the gasket between the manifold and the mid pipe. It is made out of a very soft metal and will disintegrate over time from the flex and vibration.
Old 05-05-2013, 02:22 PM   #3
MaXx0909
I'm thinking about changing it myself, i've put a clothes in my muffler to check if i could hear any exhaust leaks and i could'nt , but when i'm in third or higher gear i can hear air coming out , so i'm assuming it is my gasket,
just gonna ask to make sure, do you guys think it is, i dont know wanna go throught all that trouble just to find out is isnt that
Old 05-05-2013, 04:14 PM   #4
It is no doubt the gasket.
This is what mine looked like at 143K. http://www.yarisworld.com/forums/showpost.php?p=613496
Lift up a corner of the car and crawl under. Grab the down-pipe and wiggle it. With the gasket shot, it should feel quite sloppy when wiggled.
Old 05-05-2013, 07:52 PM   #5
Viperoni
Drives: 2005 Toyota Echo
QFT
The bolts usually come out decently easily, not particularily long or hard to replace the gasket on a driveway.
2006 Saturn Ion Redline
Old 07-29-2013, 11:30 PM   #6
kuessemir
New Owner, Longtime Fan
Drives: 07 LB-Red-Manual-Power package
Hello! Thank you for posting the pics! I possess only basic automotive knowledge; however, after performing a cursory visual inspection of the exhaust manifold and connnection to the down pipe, I believe I have the same problem with my Liftback. While cruising at a constant speed no exhaust noise is apparent; however, pressing the throttle to make traffic velocities does emit the sound of a leaking exhaust. I believe this is so because my '97 Corolla had a deteriorated exhaust manifold/down pipe connection and a similar (though more severe) sound was produced. If I were to attempt to remedy this in my garage, what might I expect in terms of repair difficulty, and time requirements. I feel that the exhaust manifold is in need of replacement; it looks poorly. I can post some pictures tomorrow when I have a moment to snap some. Any DIY advice is appreciated :-) !
kuessemir is offline   Reply With Quote
DIY: Installing Greddy TI-C Exhaust System redyaris DIY / Maintenance / Service 13 08-01-2009 05:05 AM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 10:23 PM
What exhaust manifold is the best.. gmodder Performance Modifications 9 03-29-2009 12:31 AM
GReddy prototype = Free Exhaust! Chris_Lum California 30 02-27-2007 11:13 PM
Fujitsubo Exhaust!! MC-BPT Sponsors Classifieds Area 17 11-16-2006 11:36 AM
