Old 05-05-2013, 08:26 PM   #1
Wisher23
Drives: LB
LOTEK Springs installed.
Decided to be a guinea pig and tried these ebay springs out.
Picked them up for $80 shipped to my door.
They claim to be a -1.9" drop front and rear. I have no idea what the spring rates are. Here is a before pic.
4x4 status. Then about a 45 minutes later here is the end result
Another one.
They are just as low as my tein s-techs were. The ride is comparable. Handling is way better then stock.
Happy !
Wisher23 is offline   Reply With Quote
Old 05-05-2013, 09:05 PM   #2
You did 4 springs in 45 min.!
Will be interesting to see how well the powdercoat stands up.
Old 05-06-2013, 01:04 AM   #3
Freestylin
Freestylin's Avatar
Drives: 09 Blizzard Pearl RS LB
Nice..need to see a speedrun on the 45 minute job though.
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna
Freestylin is offline   Reply With Quote
Old 05-06-2013, 01:44 AM   #4
Wisher23
Drives: LB
The rears take 5 minutes, you don't even have to take off the wheels. 15 min per a corner in the front. I've done it many times already, plus the use air tools makes it wicked fast!
Old 05-07-2013, 01:29 PM   #5
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
did you have to take out the plastic panel and the windshield wipers.. coz its kinna hard to get to that hex nut that requires hex keys...plus the bolt around it..
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 05-07-2013, 04:14 PM   #6
^ Not if you have a 17mm OFFSET box wrench.
Old 05-07-2013, 04:42 PM   #7
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
ahhh air tools lol it takes 15 minutes just to work some of the bolts off on my fronts lol
Old 05-07-2013, 04:59 PM   #8
TOLMACH
Drives: soarer
+1
Took me 3 hours
Old 05-07-2013, 06:34 PM   #9
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
It took me nearly 12 hours to do my suspension job. About 10 trips to the hardware store trying to find a dang wrench that would remove that nut on top of the front towers.
Old 05-07-2013, 08:21 PM   #10
mr_miles
Drives: 2013 Yaris
Offset box wrenches are the best inventions ever.
Old 05-07-2013, 08:59 PM   #11
TOLMACH
Drives: soarer
I was lucky - the nearby Crappy Tire had this wrench set in stock ))
Old 05-07-2013, 11:09 PM   #12
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Looks like the rear springs need about a 10mm spacer
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 05-10-2013, 03:37 AM   #13
Wisher23
Drives: LB
Yeah i lost the rubber pieces a few installs ago. its just metal on metal. After riding around for a few days the ride is ok. Its not as nice as my tein springs were. The teins gave a smoother ride, these feel the road alot more.
Old 05-10-2013, 10:40 AM   #14
1.5
Form>Function
1.5's Avatar
I agree with Malibu. I really like the low you get in the rear but it looks awkward since the front doesnt go as low.
Old 07-15-2013, 12:56 PM   #15
d3310n
Drives: black titty
so 2 months later how are these? can we get an update?
d3310n is offline   Reply With Quote
Old 08-02-2013, 03:05 AM   #16
Henry_mak16
Henry Mak
Drives: 2009 Toyota Yaris 2dr-hatchbk
Did you have to cut the bump stop? How is doing now?
Henry_mak16 is offline   Reply With Quote
Old 08-02-2013, 12:40 PM   #17
racerb
You must have mighty small hands!! I had to remove all the cowl pieces just to get enough room for using the 6mm allen wrench, then again all mine are T-handle! Now that I know the trick, it will be much easier next time, even still, it only took a few hours to change 2 struts/springs and 2 shocks/springs, didn't think that was too bad for an old man!!
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Micro Image lowering springs 1.8" drop markylicious Middle East 144 10-30-2011 02:18 AM
NEW Springs CAyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 06-25-2011 11:37 AM
have problem ! Installed tokico/eiback springs annn Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 12-27-2010 01:59 AM
Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed RedVitz Photo-Video-Media Gallery 18 10-09-2010 04:36 PM
What springs should I get? Help! CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 01-26-2009 07:32 PM
