Performance Priorities....What goes first?
OK, So.
Time to get down to business. i was all set with a little chunk of change to dump on garm for some wicked awesome bolt-ons, but family comes first and now thats all gone. so slowly, paycheck by paycheck, i will now have to buy things slowly. The Rundown My Car: 09 yaris sedan My Goal: 200whp My Actual Goal: Whatever i can get out of a sedan with a slush box. (TOYOTA ARE YOU LISTENING!!! FOUR DOOR SUB-COMPACT PERFORMANCE CARS ARE COOL, SO GIVE US A FACTORY FIVE SPEED ALREADY!!!!) The Plan Starting at the front I suppose 1.) DC headers 2.) NST pulleys (do underdrive pulleys make your a/c not work as well?) 3.) Undecided on an Intake, suggestions? 4.) Nitto mid pipe, does anyone have a link to buy this thing? 5.) DC axle back 6.) Tien springs 7.) Tokico blues after its payed off i am going to turbo the shit outta this thing, but thats a ways off. in the mean time i will just read about how awesome a ball bearing turbo would make my life what order should i buy stuff? i cant decide. I have a few questions as well. Is a Grounding kit useful or worth anything to a non swapped motor? Is there a performance intake mani availible for us? (cough cough garm) Is there something ive missed well at any rate ill buy as much as i can from micro image and see what kind of madness i can get out of my slushy sedan. |
![]() ![]() ![]() ![]() ![]() Drives: Toyota Yaris Sedan 09 STD Join Date: May 2009
You want 200whp?!?! Get a Turbo!
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
you'll never get 200 hp out of this thing without spending tons of cash in finding someone to reprogram the ECM or finding a standalone fuel management system.
second, you'll never reach 200hp without some sort of power adder...easiest but most unreliable (longevity terms, not power terms) is nos, and it's also the easiest and cheapest to install and upkeep. you can get a 100hp kit from anywhere for less than 600 bux, fill the tank for 30 and even pay someone 200 or so to install it....so for less than a grand you got 200 hp total. but, i wouldnt go more than about a 35 shot if i were gonna keep it as any sort of driver. you can turbo, there are kits for about a grand out there...or you can pay more for better gear (i'd definitely suggest paying more than a thousand for a turbo setup...you get what you pay for) but, for you to dream that you'll hit 200hp naturally aspirated on the stock engine is just...sensless. now, put a celica engine in there...sure...drop a honda engine in there...sure. but, the stock 1.5l engine will likely never see 200 hp without some sort of power adder. there are no cams available, no tuning software, no heads, and people have even used different combos of pistons/cranks and still not reached 200 hp. someone here has a blitz supercharger and he's only at 135hp. and there's a turbo car somewhere around the 175 range. but to answer your question, if you want to start somewhere, start on suspension. because no matter what you do to engine/turbo/sc/nos, whatever....you'll always use the suspension. and unless you change engines, you'll always use the same suspension design or similar. so...i'd go springs/swaybar/shox n struts. if you do turbo you're wasting your money on axleback and headers and midpipe. and if you supercharge, well...you need all that stuff, but you may need bigger than whats available...so wait till you 'need it' to get it. pullies are always good, intake...again, if you go turbo you wont need it, and the supercharger comes with it so .... whatcha gonna do there??? and again, check the for sale section, there's always goodies in there for ya. i got my AFE intake for 50 bux, HID's for 50 bux, and a pulley set (almost) for about 50 bux. |
1. intake
2. lowering springs 3. rims + tires
Unless your garm pushing 300+ hp all built up engine turbo wat/met inject etc etc lol otherwise with just those addon's you posted you would probably get about 5-8 hp gain no more.
If you want to do 200+ whp go online and search car-parts.com or go to a junk yard and buy the same engine to build in your garage, engine shouldn't be more than 800$, i found some nearby me for 400$ even with only 10k miles on them and so on. heres some information on what garm did on his built engine http://www.microimageonline.com/foru...-turbo-project I tried searching but I remember finding a post with a link to a website with instructions on the build. Basically you need to shell out close to $10,000 depending, if you do it all yourself it will be less.
a.k.a. "Aothachos"
I got 17 whp from the bolt-ons and have the dyno to prove it. It's a respectable gain and you can feel it.
There should be a turbo kit available soon that pushes about 150 whp. 200 will require a turbo and a tune on the dyno, and a stock motor probably wouldn't handle it for a long time. An N/A 200 whp would be a really fun project, but a LOT of work. let's see how the Gude cams do on H3llion's car, there may be some hope for more substantial bolt on mods yet.
I suppose 200whp is extremely ambitious...
thanks for bringing me back down to reality lol ![]() I've talked it over with the wife and i could just get a rsx and boom presto 200hp but i really like my yaris and i dont want to abandon it just because he is a little under powered, and i feel like a motor swap is losing its character... unless maybe to a 2nz or what ever the carolla motor is with the vvti... so i suppose figure out a carolla motor build, or be happy with what i have, because as it is, its already a fun nimble little car. i mobbed down to long beach for spocom driving very irresponsibly and still had a blast and got 36mpg. maybe thats the whole point of a sub compact....i just had an epifany! im just going to stick with whats availible for the stock motor bolt some shit on and appreciate the car for what it is. Last edited by jcemitte; 07-20-2010 at 12:25 PM. Reason: my eyes have been opened |
^ that sounds like plenty of fun.
Don't forget, as other have mentioned, that some handling mods make the car even more fun.
200HP NA has been done by G-force garage in japan.13:1 compression,cams,
ITB's and a new gear set for the trans. |
#10 | |
![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
The potential for performance (and especially handling) is there, you just need to realize it. It's pretty funny that no one I know takes a Yaris seriously. The other day I took one of my nay-saying buddies out for a spin and as soon as he saw how flawlessly the car was taking turns at 70+ mph he shut up pretty quick.
#11 | |
![]() .... and the guy you took out for a spin.
OMG my wife is killing me!!!!i just called her and asked (i have a vaction coming up this weekend mind you) if i could spend $480.00 on some springs and shocks/struts she said no then i asked if i could spend $280.00 on aformentioned shocks/struts she said no then i asked if i could at least buy the springs you guessed it...no then i reminded her that i spent $280.00 so we could leave a night early and stay in the room for a total of four hours and told she owes me at least a cold air intake she said no im dying to buy something and im not good at patience. |
#13 | |
Or Negotiations eathier, reading the above
#15 |
god i know remind me to look for my balls in her purse when she gets home sheesh
i might just order it anyways you know get my man hood back not likely |
#16 |
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
I am starting with the simpler stuff first.
Just ordered the TRD exhaust. Then I'll get the TRD CAI when I have some money to burn. After that, prob DC headers. |
#17 |
LOL @ the wifey story. I got no advice for you, mine is cool that I am pursuing my passion, as long as the bills are paid.
#18 |
so...are those cams available yet? i'm not doing anything until they are. i'll do it all at once n be done with it.
also, how's the programming/timing issue going to be solved with a cam swap? |
| The Yaris Performance Primer | eTiMaGo | Performance Modifications | 30 | 01-24-2024 04:26 AM |
| December at TWM Performance! | TWM Performance | TWM Performance | 17 | 01-08-2010 09:14 AM |
| >>>>>> Boxing Day Sale at TWM Performance; Short Shifters and Shift Knobs <<<<<< | TWM Performance | TWM Performance | 0 | 12-24-2009 10:21 AM |
| Black Friday SALE from TWM Performance! | TWM Performance | TWM Performance | 1 | 11-27-2009 11:46 AM |
| Yaris Performance Specs | neohalo | Performance Modifications | 22 | 06-24-2007 08:46 PM |
