![]() Drives: Toyota Yaris Track prepped Join Date: Nov 2013
Track Yaris from the Netherlands
Hi guys
I'm William and from the Netherlands. I drive a track prepped Toyota Yaris MK1 Original 1.3 car with 0 options and 2nzfe Swapped to 1nz-fe Stripped interior Lots of strut braces/swaybars and coil overs with custom spring rates semi slick tyres Custom full exhaust Rollcage, bucketseats, 6 point seatbelts etc etc Car is being raced in the Dutch Time Attack competition, track days and the Nurburgring / Nordschleiffe Cheers! ![]() ![]() ![]() ![]()
nice. that's a true MK1 with the antenna at the front.
facelifted MK1 (teardrop headlight) has the antenna at the back :) |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Badass
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
awesome.. why do some runs you have different headlamp assemblies?
On track i use a morette headlamp with a custom tube for cold air feed, But on the Nurburgring you arent allowed to drive with that setup as it is technically a german motorway with all rules off the german highway code (no right overtaking, lights on etc)
Interesting.. I didn't know that
Nice looking car.
All we have are the sedans here in the states.. But god I love those hatches so much.
STOP!
![]() Supercharger time! ![]() ![]() Its a complete TTE Supercharger kit. Took everything off today and removed the bearings as there is a lot of play on them, Gonna replace them all. The rest of the kit is in perfect shape so won't take long for it to be completed and installed! |
Lmao. Well done gifs
![]() New bearings have arrived! They are SFK made type-3 bearings which will handle 35.000 rpm. So shouldn't be a problem for the charger as it only revs to 12.000 rpm max. If anyone is doing a TTE charger refurb and needs the bearing type nr's just give me a PM. Putting the charger back together on monday and hopefully install it on the car very soon! |
How much boost is this charger pushing?
i'd say max 0,5/0,6 bar. You could increase that by fitting a lightweight pulley but your stock internals will only take max that amount of pressure, You should fit some uprated springs and seats and maybe some con rods if you want to push it with more bars
![]() Put the charger back together with new bearings and installed everything. Now on the hunt for a new belt. We can't use the belt from the kit because i don't have AC, so need to find a new one with the precise length needed. Hopefully we will find one tomorrow and start her up!
![]() She's home! and o my, she is quick xD Installation went ok, we ran into some problems regarding the bracket of the alternator etc but nothing some spacers and washers couldn't fix. The belt we used is a 4PK1440 but i'm gonna replace it with an 4PK155 because its just so much easier to put on and off where as the 1440 is really tight! Its really quick! the charger is brutal. Put my foot down a couple of times and had to turn around to pick up my intestines haha. Should be really fun on the track! Munching Vtec bwahahaha omnomnom |
Based on your picture above, the TTE SC looks identical to the Blitz, so I would definitely be interested in the bearing part numbers for future reference.
#17 | |
sooooo
Charger is up and running, well it costed me a belt due to a nut not being tightened enough causing the belt to tear along it, but now thanks to some handy search work i used a industrial Gates 4PK1455 ES belt which is used for tractors and busses haha. Quote:
There are 5 bearings which are best to replace or upgrade, Just 2 types, 1 is from Toyota themselves (Made in Korea, lol) 1 is from Ogura (the manufacturer of the charger, Made in Japan) 2 of them are small and 3 are larger ones. The charger itself & pulleys revs up to 12.000 rpm so don't use any bearing because the wrong one will burn and lock up and you charger can go into the bin. Removing of the bearings is pretty straight forward. Just use a press and a large socket wrench size 22/24 to push them out, Or a hammer ![]() So after some research i did for the refurbishment of the bearings i found some replacements Manufacturer: SKF Model nr: 6301-2RSH/C3 (2x) These are the small ones 6303-2RSH/C3 (3x) These are the larger ones The C3 code is important because those are heavy duty bearings which will take up to 35.000 RPM!! cheers |
#18 | |
| August 18th Sunday-Touge.ca Mosport DDT track event 12:30-5pm #15 of 20+ Events! | Touge.ca | Canada | 1 | 08-17-2013 06:00 AM |
| Touge.ca June 23rd Shannonville Full Track event 6 - 9pm, 10th event of 20+ 2012!! | Touge.ca | Canada | 0 | 06-14-2012 02:09 PM |
