play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
non starting mystery...
Got a mystery here, and these are the symptoms:
When the key is in the ON position, all the accessories work, except the instruments don't turn on and the led section of the dash remains blank. And when turning to START nothing happens. No cranking. No clicking. Nothing. Removed and tested all the fuses. They're all good. Everything looks all plugged in like it should be. Plugged in the OBD computer and turned the key to the ON position. It powers up and tries to communicate with the ECU but says it can't and says make sure key is in the ON position. I'm stumped... So does anyone here have any suggestions on how to solve this mystery? I'm open to trying anything. Greg |
Mr. 155 and climbing
Have you done any work with the ignition or ECM lately? Have you checked your battery terminal that they are clean and have GREAT contact? I ran into that actually at NEFR and found out that the culprit was the link in the middle of my disconnect assembly.
#3 | |
play every day
![]() By the way, do you know of any interlinks which prevent turning on the ignition? Everything else works except the ON and START positions of the key switch. The ACC position works normally. |
I think it may be your new manifold!
I would triple check the AM2 fuse in the under-hood fuse panel. If that is OK. Listen to the relay module below that fuse while someone else turns the key from OFF to ON and see if the IG2 Relay clicks.
play every day
Ok, Scott, I will.
Correction: You have a 3rd gen. Still check the AM2 fuse under the hood, but the IG1 and IG2 relays are now in the junction block assembly under the driver's side of the dash.
Also, do other things work or not work with the key on (like wipers, headlights, blinkers, radio, etc.)?
play every day
The 10amp IG2 fuse is good.
The relay does not click when the key is turned. The relay coil terminals have continuity. |
play every day
#10 | |
play every day
One relay under the dash clicks in the ON position, another clicks in the START position. But no instruments and no starting. Last edited by tooter; 08-08-2013 at 04:39 PM. |
#11 | |
![]() Your symptoms are very intriguing to say the least! Best of luck...I will be following to hear the outcome.
play every day
Ok. I'll check the grounds.
At this point I'm trying everything.
play every day
Checked the grounds and they're all intact. Does anyone else have any ideas?
#14 |
Problem, officer?
Drives: '06 Yaris 5DLB 1.5 Join Date: Oct 2010
Can you turn on your A/C blower fan in the ON position?
#15 |
Check the 60A fusible link on the positive battery terminal.
#16 |
play every day
#17 |
play every day
Took everything apart at the positive terminal and both the main and the alternator fusible links are good. And there is power at both the alternator and the starter.
You know, it is behaving like there is something disabling the ON and START circuits from operating. And although the OBD computer powers up fine, it is not able to communicate with the ECU, so there seems to be no power going to the ECU. Might you know if there any sort of "fail safe" disable mechanism that may have gotten triggered? I saw in the Owner's Manual there is an anti theft ignition disable security device, although my model supposedly doesn't have it because there is an empty spot where the LED indicator would be at the leading edge of the dash near the passenger side of the windshield. I'll try any other suggestions you can think of... |
#18 |
The cluster gets constant power from the ECU-B fuse and switched power from the MET fuse and illumination power from the PANEL1 fuse. It also gets a power feed from the HAZ fuse, as it directly drives the turn signals.
The IG2 Relay feeds the MET fuse power. If all of those fuses are good, check the voltage on the light blue (ECU-B) and pink (MET) wires, which are right next to each other on one corner of the larger cluster connector. The ECU-B should have power all the time and MET should have it only when the ignition is on.
| When cold starting, almost sounds like opening a fresh 2-liter Coke bottle | Shinare | DIY / Maintenance / Service | 8 | 06-03-2013 05:18 PM |
| 2009 Yaris starting issue -need help | cudchew | DIY / Maintenance / Service | 15 | 12-16-2011 03:24 AM |
| Yaris Starting Mystery – Help Please! | ceilingwalker | DIY / Maintenance / Service | 3 | 11-10-2011 06:35 PM |
| Problems starting the engine | fmicle | General Yaris / Vitz Discussion | 10 | 10-07-2009 09:48 AM |
| Starting Engine - Yaris Hatchback M/T | gbuks | General Yaris / Vitz Discussion | 2 | 11-06-2008 01:24 PM |
