Old 03-21-2007, 01:52 PM   #1
hans_fh
Drives: Yaris
Driving car at 75mph on position 3 :(
Yesterday, I drove the Yaris Sedan to airport. On the way home, my friend on the passenger seat touched the transmission shift from position "D" to "3". But I didn't notice that and the engine noise is very loud because I was driving at 75 mph. When we got home, I realized that I had been driving the car on "3" for 3 hours!!
Is it really bad for my car???
hans_fh is offline   Reply With Quote
Old 03-21-2007, 01:55 PM   #2
Pavel Olavich
Drives: 2007 Yaris LB
No, not bad at all....worse case you wasted some gas. I suppose one could argue that driving like this is harded or places more stress on the car, but I doubt you did any damage...you're just out some $$ on gas that didn't have to be burnt.
I routinely move the AT selector from D to 3 to engine-brake the car's speed. I'm careful to be mindful of the speed of the car, as doing so going too fast for a lower gear can kick up the RPM's.
I routinely engine-brake from D to 3, then 3 to 2 conditions depending.
No harm to your AT, to be sure, assuming you do it right.
No worries to your Yaris, sir!
Pavel Olavich is offline   Reply With Quote
Old 03-21-2007, 02:15 PM   #3
ChinoCharles
Drives: LB
I never understood this. If you want the ability to engine brake, buy a manual! Putting extra wear on your expensive, complicated auto tranny isn't worth it! Brake pads are cheaper!
My buddy has this early 90's escort that is a total heap, but it only has 60,000 miles. Engine and everything is pristine, but the body is shot. Typical Ohio car. Its an auto. When I got my Yaris and started playing with it, he would ride with me and I would be shifting from gear to gear. He must have had race car envy. Low and behold a week later he started engine braking with his auto tranny. Now, his car sits in his yard. Tranny problems. I'll let you guys know when I'm done laughing at him.
Pavel's right though, all you did was burn some gas. No worries.
Old 03-21-2007, 03:24 PM   #4
spkrman
Drives: 1
well it was also a ford
Old 03-21-2007, 03:32 PM   #5
forpinks
forpinks's Avatar
Drives: 03 Toyota Corolla S modded,
FORD- Fix Or Repair Daily, Found On Road Dead.... give me more please...
forpinks is offline   Reply With Quote
Old 03-21-2007, 04:12 PM   #6
RemieGino14
RemieGino14's Avatar
Drives: 2010 5dr Hatchback Yaris
Send a message via AIM to RemieGino14
Fix On the Road Daily
- RemieGino14 -
'91 Midnight Black, Acura Integra RS - Crashed
'07 Silver Mica, 4dr Toyota Yaris - Crashed
'99 Cypress Green, Acura 3.0 CL
'10 Carmine Red Metallic, 5dr Hatchback Toyota Yaris
RemieGino14 is offline   Reply With Quote
Old 03-21-2007, 04:47 PM   #7
zerofloat
zerofloat's Avatar
Drives: 07 Liftback 5 speed
First on race day -- NOT
Fricked over redone dodge
F ing owner real dumb
zerofloat is offline   Reply With Quote
Old 03-21-2007, 05:27 PM   #8
SailDesign
Drives: .
F%cked Over Royally Daily
Old 03-21-2007, 03:29 PM   #9
Pavel Olavich
Sorry friend but you're out of touch with the realities of auto-tranny's sir....even Toyota suggest engine braking, and it shows in the Yaris 2007 LB owners manual.
I've owned many, many AT cars domestic and foreign, and after 100's of thousands of miles driven with engine braking, NEVER a transmisison problem. Never. Your friend's Ford Escort is a piece of sheet, and not representative of using engine-braking with a decent car. I just left a Ford Mustang for the Yaris and let me tell you that Ford produces a crap product...but that's another thread....lol
The Toyota AT in the Yaris is near bullet proof, and using the engine to slow the car down is NOT going to harm the transmission in ANY way unless one does it wrong, like dropping into 2nd gear at 75 or something crazy, but then that is also true with manual cars too.
The "brake pads are cheaper" thinking only is true if you drive a sheet car with a sheet tranny....this thinking does not apply to Honda's nor Toyota's and this is perhaps true with all Japanese products. With a Toyota AT, you can save your brakes and NOT at the expense of a big Tranny repair bill.....you can have it both ways.
Old 03-21-2007, 08:56 PM   #10
ChinoCharles
Drives: LB
Its called rev matching. Can't do that in an auto. Does the Yaris auto tranny do it for you?
Old 03-21-2007, 09:44 PM   #11
Pavel Olavich
No need for rev matching with an automatic. The torque converter has enough play to buffer the differences between the motor speed and the tranny speed...it's fluid driver after all...the lock up torque converted is disengaged at this point. The net effect of engine-braking is a decrease in car travel speed, and this saves on brake pads, but not at the cost of transmission damage.
Old 03-22-2007, 12:57 AM   #12
ChinoCharles
Drives: LB
Hey, did I BUY Ford?
Pavel, jolly good show. I'll shut up now. Engine brake away.
Old 03-21-2007, 10:08 PM   #13
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
I can't believe you Chino! And you call yourself one of us. You should know you can't ever compare a Toyota to a Ford. You break my heart and have forced me to question every post you've ever made. You don't deserve your Yaris regardless of transmission type... Just kidding Biotch! But, I have to say that engine braking with an auto does no harm to it, however, yes it is easier and more effective with a manual.
Old 03-21-2007, 03:23 PM   #14
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
Brake pads are WAY CHEAPER! Just use brakes! Auto or manual, just use brakes...
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 03-21-2007, 04:02 PM   #15
Pavel Olavich
My 2003 Expedition drove great...fantastic really, with it's rear independent suspention, but it was not reliable....at 10,000 miles the rear differential had to be replaced, at 13,000 driver side window motor went out, at 19,000 miles the power stearing went out, at 26,000 miles the tranny started leaking....then I replace it with a 2006 Mustang, and it had even more problems....It was a happy day I got the Yaris....it's back to Japanese cars for me
Old 04-02-2007, 06:50 PM   #16
captainzerocool
CAMRY FTW!
captainzerocool's Avatar
Drives: Camry LE V-6 (225,000+ miles)
I always wondered why ford could put independent rear suspension in the trucks but not the Mustang? That sounds hella stupid.
I drive a Camry.
I have no imagination.
captainzerocool is offline   Reply With Quote
Old 04-03-2007, 12:40 PM   #17
Pavel Olavich
It is stupid that Ford has no independent in the rear, and for a so called sports car too. Funny though, if you go to Mustang forums the idiots actuallyt defend the absences of independent in the back...strange....
Old 03-21-2007, 05:43 PM   #18
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Dont worry, nothing went wrong.
Regular car wash, or Dealer car wash? Buckethead Wash, Wax, Detailing, Exterior Repairs 49 07-21-2007 12:46 PM
How to Be a Street Racer - General Life Guide MDF Off-topic / Other Cars / Everything else Discussions 7 03-19-2007 12:49 PM
REALLY BAD CAR ACCIDENT! MacMaster761 General Yaris / Vitz Discussion 25 11-30-2006 11:20 AM
[Detail] [as to make ] Auto Laudering Sérgio Barros Wash, Wax, Detailing, Exterior Repairs 4 08-22-2006 03:56 AM
