Old 10-02-2013, 07:09 AM   #1
BLOODY_STONE
Drives: 2009 toyota yaris 1.3 sedan
best setup for bumpy roads ?
hi guys
i was looking forward changing my stock tyres (185/60 15) with a new setup .. and buying new wheels too !
any recommendations for my new setup ? like my tire size and wheel et. ..
roads here are really bad .. bumbs like every 100m ..
i won't change the stock suspension as i need the car to be high enough not to cause any rubbing issues even at full lock ..
HELP!
BLOODY_STONE is offline   Reply With Quote
Old 10-02-2013, 10:50 AM   #2
Anything larger will be worse in bumps. With aftermarket wheels, cheap can crack, dent and break, buy the best quality you can afford.
Other than that, the question is too big to answer. What wheels do you like? (see threads on here with pictures of aftermarket wheels).
Old 10-02-2013, 11:09 AM   #3
BLOODY_STONE
i wont change size .. 15" are good for ride comfort ..
im just worried about the wheel offset change as roads are extreme for the suspension and weight bearings ..
also tire size .. im thinking of 195/60 but not sure if it would cause rubbing .. because we drive in extreme traffic here so it is frequent to use full lock :-D and bumbs of course ..
Old 10-02-2013, 11:22 AM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
195/60R15 is fine, but your car will go faster than your speedo and hence losing abit of torque. You will sit about half inch higher than usual.
I've been driving with this for the past 3 years though. You definitely want to stay with 185/60.
Old 10-02-2013, 11:48 AM   #5
BLOODY_STONE
i dont care about speedo changes .. i dont want to lose acceleration as this car is a low powered 1.3
thanks for your advice
Old 10-02-2013, 11:45 AM   #6
BLOODY_STONE
another thing .. most of the wheels here are 6.9 kg (15.21 lb) .. and offset +38 ..
is that lightweight or no ?
lighter than stock steelies or same?
and that offset is ok for the weight bearings and rubbing?
Old 10-02-2013, 12:13 PM   #7
15 lb. is an average weight, not overly heavy or light.
+38mm is fine until you get into a 7.5" or wider wheel.
You won't hurt your bearings. I run 15x9 all the way around, race the car, and have never had a bearing fail.
Old 10-02-2013, 09:02 PM   #8
BLOODY_STONE
so i should get lower than 15 lb? and no change in tyre diameter ?
recommend pls
Old 10-06-2013, 07:33 PM   #9
BLOODY_STONE
i found some 15" wheels with 11 lb weight and offset +40
what about 195/60 tyres?
any rubbing issues?
will the acceleration be affected? i mean the lighter wheels can lower the effect of wider tire ?
Old 10-07-2013, 02:29 PM   #10
IllusionX
any rubbing issues?
i have 195/60 for the past couple years. no real world difference beside sitting half an inch higher than usual.
You probably would see a different in your 1/4 mile run though. But does that really matter? i think not.
Old 10-07-2013, 04:12 PM   #11
BLOODY_STONE
no it doesn't matter to me .. i was just worried about rubbing ..
Old 10-07-2013, 02:38 PM   #12
From what I have seen of Egyptian roads, I don't think that light weight alloy wheels will survive the punishment (as Garm mentioned in the second post). I would go with wheels intended for rally racing, like OZ Racing, Team Dynamics, Braid, etc.
Old 10-07-2013, 04:11 PM   #13
BLOODY_STONE
i'll keep looking .. such brands are rare to find here ..
I appreciate your advise ..
anyone know a good suspension setup for rallyx? Yay Tracking, Racing, Auto-X Forum 2 06-29-2011 03:35 AM
)) Steering wheel hub setup (( aucorium Cosmetic Modifications (Exterior/Interior) 4 04-30-2011 05:09 PM
Why this girl will never "race" on back roads again .... JBougie Off-topic / Other Cars / Everything else Discussions 11 11-18-2010 03:10 PM
anyone wanna sale there turbo setup for $1000 1.5ty Willing to Buy by private party 0 06-02-2010 03:51 AM
Best SoCal driving roads? yarswiss Tracking, Racing, Auto-X Forum 17 09-07-2009 09:28 PM
