![]() Drives: Toyota Yaris 2008 Join Date: Mar 2015
Engine won't start
Hi to all,
I have a toyota 2008 yaris, battery is 3 mos old and after 3 to 4 engine start and drives around with A/C on and lights on, it losses power and it won't crank up the engine. I know the alternator is working as I disconnect one battery pole connection and it still runs. It seems as if its not charging via alternator. can anyone help me out here, I am kinda lost with this one. |
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
Check the output of the alternator with a meter.
If you don't have a meter most big box stores will check it for no charge. Norton |
Check the large fuses on the positive battery terminal the one between the alternator and battery may be popped.
#4 | |
also we did that while in the battery dealer, the fuses are intact and the meter shows continuity. Is the charging system has any connection to the computer module? |
The battery dealer may have checked the fuses in the fuse box, but not the ones on the positive terminal. Those are built into the plastic assembly, so you can't easily check for continuity.
| The Yaris Performance Primer | eTiMaGo | Performance Modifications | 30 | 01-24-2024 04:26 AM |
| Boost Gets U Laid eh? Count me In | yaris2010RS | Forced Induction Forum | 128 | 02-02-2013 04:57 PM |
| slight clutch kickback after engine start?? | marcus | DIY / Maintenance / Service | 0 | 09-17-2010 11:05 AM |
| The last gas question | Tonavi | DIY / Maintenance / Service | 56 | 04-27-2009 08:40 PM |
