![]() Drives: 2007 yaris 4dr sedan Join Date: Oct 2013
Power Locks
Perhaps a Toyota guru can give me some tips on how to fix this issue:
My driver side front door will not close when I press the key lock. The same happens even when I try to lock it manually with the key, dumb lock lol. Any ideas Yaris freaks out there
![]() Drives: 2011 Yaris 3dr Join Date: May 2013
Are you saying if you lock the door while it's open, the door will not latch shut?
On my car it won't allow to lock the car with either door open. |
Hi,
The latch doesn't shut. I close the door all the doors and they latch shut. Only the driver side front door doesn't latch shut. When I hit the key I see the mechanism move back and forth but it don't latch shut. |
It latches fine when not locked, but won't latch when locked? If so, I would start by lubricating the latch mechanism at the edge of the door. If that doesn't help, you will have to remove the lock to examine it further.
One other thing to check is when the door is locked, does the pull handle on the inside feel the same as the other doors?
Door will not latch when locked.
Drives: Toyota Yaris Join Date: Nov 2013
hey all - new to this forum and have a similar problem. My front passenger door of my Yaris does not latch when i lock them with my power lock on my key. I have to always tell the passenger to manually lock the door as they exit. Kind of embarrassing. However, all other doors lock with my power locks. Even when I'm in the car and we are driving and I try to lock all doors with from the driver side, my passenger side door does not lock. I'm trying to figure out what the actual problem is and how to resolve it without spending tons of dollars at the dealership.
Many thanks in advance! |
#7 | |
| Installation of original power windows and locks in Yaris | lantis | DIY / Maintenance / Service | 4 | 02-25-2012 02:38 PM |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
| Question about Power Locks | absolution8 | General Yaris / Vitz Discussion | 3 | 05-30-2011 07:20 AM |
| Power windows and locks on a 2009 3dr. | chilly79 | DIY / Maintenance / Service | 8 | 12-15-2010 01:55 PM |
| Questions and advice required about power upgrading(windows & locks) | W.A.S.P | DIY / Maintenance / Service | 10 | 07-22-2009 03:59 AM |
