Old 12-05-2013, 10:54 PM   #1
elli196
Drives: Toyota
Help needed! Changing wheel/tyre size will it rub with this size??
I need help, I have a 09 Yaris YRS sedan sitting on stock tyres at the moment size 185/60 R15. Wanting to change on new rims sizes 205/40 R17x8. Will they have a good fit with no sidewall rubbing or anything like that? By the way stock suspension is installed still.
elli196 is offline   Reply With Quote
Old 12-06-2013, 05:24 AM   #2
Lars
Yaris beginner
Drives: Yaris XP9F
As far as I've seen in other threads the rule of thumb for wheel sizes (diameter) is to keep it under a 3% variation from stock... So calculate your old and new diameter and see if it's according to the rule of thumb... if not, it might rub but yeah... it depends on offset as well and I'm no expert ^_^
Lars is offline   Reply With Quote
Old 12-06-2013, 02:27 PM   #3
elli196
Drives: Toyota
Yeah true thanks for pointing that out haha helped me understand a lot more
Old 12-06-2013, 01:33 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
205/40/17's are too short for stock suspension. Go with 205/45/17's for an OEM fitment
Old 12-06-2013, 02:29 PM   #5
elli196
Drives: Toyota
So with either tire aspec ratio they'll still have a good fit or? Besides If I do have enough clearance with the 205/40/17 I'll probably lower the suspension by a few inches.
Old 12-06-2013, 04:05 PM   #6
kimona
kimona's Avatar
If you're planning a 2" drop, then go with 205/40/17's.
help!, toyota, tyres
what 16" wheel size and tire to not rub on trd springs nerdrage Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 06-30-2011 12:27 AM
tire size change advice needed aucorium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 02-23-2011 04:24 AM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
