Old 02-13-2014, 04:33 PM   #1
coffiend
coffiend's Avatar
Drives: 08 Black LB
Broken part needs identifying
Hey dudes and ladies,
I was changing my belt out and broke an electrical connector off of some part of my car. I'm not sure what it is but I need it identified so I can call toyota to get a new one. Here's a couple pictures. It's a 2 prong connector that connects to the alternator. The broken side came off of the cylindrical looking guy connected to the engine, that's the part I need identified.
first picture shows where the connecter broke off from, second shows how it's supposed to looks.
thanks in advance!
Old 02-13-2014, 04:39 PM   #2
coffiend
coffiend's Avatar
Drives: 08 Black LB
is it the VVTI solenoid?
http://www.1aauto.com/1A/VariableVal...MX00166/649326
Old 02-13-2014, 05:30 PM   #3
Yes. It is the oil control valve. I have a low mileage (3000 miles) used one that I could do $55 shipped for, if you are interested.
Old 02-13-2014, 06:10 PM   #4
coffiend
coffiend's Avatar
Drives: 08 Black LB
Thank you!
I wish I could buy yours but I need to fix it tonight.
I do have a question though. Is this 3 pieces? I pulled it out and the external part and a shaft like thing came out. But the exterior part with holes that you see seems to be stuck in the motor.
I guess my question is if I buy a new one can I slide the shaft into the existing one that is stuck in the engine so long as I tighten the exterior part so the O ring seals it? I tried to get the 3rd piece out but I just can't get it...
Thanks.
Old 02-13-2014, 06:17 PM   #5
coffiend
coffiend's Avatar
Drives: 08 Black LB
If it's not 3 pcs then part of it broke off and is stuck in the head :(
Any suggestions on how to extract it?
Old 02-13-2014, 09:18 PM   #6
This is what the whole thing looks like. How much of this is stuck?
Old 02-14-2014, 12:33 AM   #7
coffiend
coffiend's Avatar
Drives: 08 Black LB
Essentially everything past the o ring snapped off inside the head!!!
I struggled with it for an hour or so, but ended up using a weird little metal hook I found at a hardware store to catch one of those holes and yanked it out. That was pretty awful and scary. Thanks for all your help CT you sure are a good dude!
Old 02-14-2014, 03:31 AM   #8
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Gotta say, i had like a mini heart attack reading this thread. I always worry about breaking that thing off.
Check out my Build thread:
Old 02-14-2014, 03:43 PM   #9
coffiend
coffiend's Avatar
Drives: 08 Black LB
It was the worst feeling ever. I struggled for so long with some extended 90 degree pliers as well as regular extended pliers.
I thought I'd clear up what I did to remove it in case this happens to anyone else. When It broke off, I barely exerted any force on it, so I'm not sure how it snapped.
I attached a photo to show how much of it was stuck in the head, basically the entire half that has holes in it.
What I ended up doing was grabbing this little guy from the hardware store, which is basically just a coupling nut with a hook on one side and a loop on the other. I bent the hook so it was more of a 90 degree angle and fished around inside the part to find one of the holes in the side wall. When I found a hole, I put pliers in the loop end of the little tool and gave it a good pull and wiggle and it finally popped out. I then immediately poured myself a whiskey coke.
Hope this doesn't happen to anyone else. If it does happen, the little hook method literally took me about a minute to extract it rather than struggling with pliers for another couple hours. Cheers!
Old 02-14-2014, 03:52 PM   #10
Sorry that happened to you and glad you got it out. However, over the years, there have been plenty of post advising people to stay well clear of the OCV when working the belt.
BTW, your improvised tool is call a turn-buckle.
Old 02-14-2014, 03:54 PM   #11
coffiend
coffiend's Avatar
Drives: 08 Black LB
I'm sure there are several posts on the subject. But ya know... shit happens ;)
DIY - Carbon fiber wrapping Brian Wash, Wax, Detailing, Exterior Repairs 15 07-10-2016 01:34 PM
Need help finding the Japanese part number for the TRD Sway Bar (PTR11-52071) chalked Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 01-26-2013 03:29 PM
Part fall off razingman DIY / Maintenance / Service 2 12-29-2012 08:08 PM
2008 OEM S model Liftback Lip kit Part numbers PETERPOOP Cosmetic Modifications (Exterior/Interior) 17 07-26-2010 02:33 PM
NEED HELP - Yaris suspension part Trish General Yaris / Vitz Discussion 10 11-07-2009 02:44 PM
