Old 02-11-2014, 04:25 AM   #1
sobri46
Drives: yaris
Need Help to change Muffler
Hi Guys ,
Have a nice day
My car is 2007 Yaris Sedan 1300 CC
I want to change my muffler to get deep and solid tone on the car .
i found a muffler on ebay :http://www.ebay.com/itm/171035094830...%3AMEBIDX%3AIT
this is the specification :
Muffler (Silencer is included)
Style: N1 Slant Tip
Material: SUS304 / T304 Stainless Steel
Color: Chrome Burnt
Muffler Body : 12 Inch
Outlet Tip Length: 4 Inch
Outlet Diameter: 4 Inch
Inlet Tip Length: 2 Inch
Inlet Diameter: 2.5 Inch
and i see that the inlet of the muffler is 2.5 inch and my yaris exhaust pipe is 2 inch or may be less than 2 inch .
is someone know what is the exhaust pipe size for 2007 yaris sedan 1300 cc ?
and my question is how can i change the oem muffler to this muffler that have different size of pipe ?
and i dont want to make down the power of the car
please help me to change the muffler
the exhaust system is same as the attached photo
thanks and best regards
sobri46 is offline   Reply With Quote
Old 02-11-2014, 08:19 PM   #2
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
If its anything like ours...the stock tubing is 1.75"
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 02-12-2014, 01:59 PM   #3
jcboy
Drives: Sedan 07
if the 1.5L has 1.75" exhaust piping (pre-muff), then the 1.3L version of the same engine model should have a smaller one.
you can only go as far as 0.25" increase to not lose noticeable amount of torque, unless you have a turbo that needs to flow a lot of air out. on the same note, a 2.0 inlet muff can be the biggest you can go, 2.5" will be overkill (for a perspective, turbo'ed 1.6L engines only use 3.0")
although just changing the muff will not significantly affect the powerband, it will still. 0.02
Old 02-13-2014, 01:42 AM   #4
sobri46
Drives: yaris
thank you for your reply,
i think you are right that may be the exhaust pipe of my 1300 cc yaris will be less than 1.75 inch and may be it will be only 1.5 inch
if i will just cut the oem muffler, then make an adapter from 1.5 inch to 2.5 inch and add 2.5 inch pipe about 10 inch only to fit the long of the pipe after remove the old muffler and then put the new 2.5 inch muffler
with out changing any other OEM pipe or resonator or header .
do this modify will be good and will not changing the power of the car ?
i just want to get a good sound and not looking for increasing of more power or HP for the car.
the problem is i don't find any good 2 inch muffler on ebay .
please help me to resolve this matter
thank you
Yaris vs Celica jesh462 New YARIS Purchase Forum 11 10-19-2012 12:49 AM
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 12:03 PM
Yaris TRD Sport Muffler ArtS Items for Sale by private party 3 11-30-2010 10:43 PM
