Found Something
Is this new or old?
I need Verification Please! Now we come to the juicy bits. The 1.5 16 valve DOHC VVT-i 1NZ-FE engine has been turbocharged with light boost pressure as the compression ratio of the engine is still quite high for a turbo-ed engine at 10.5:1. Normal for a bolt-on setup. The ECU has been upgraded to detect boost and adjust air-fuel appropriately. This results in 143 horsepower at 6400rpm and 196Nm of torque at 4400rpm. The gearbox is a 5-speed close ratio gearbox for maximum acceleration. This takes the car from 0-100km/h in 8.1 seconds. The car does the 400meter sprint at 15.9 seconds. http://paultan.org/archives/2005/11/...ta-vios-turbo/ The link was found at the Bottom of this page! http://en.wikipedia.org/wiki/Toyota_Vios Thoughts?
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
This is real old, Thomas has Video of a Turbo Vios from WAY back when
yeah... standard TRD turbo kit for 1NZ-FE, which would cost a little upward of US$4000 if I were to get them to do it. 4K for just 50% horsepower extra's not exactly stellar
der Zeck
$4000 compared to... how much was a 2zz swap?
#5 | |
![]() Drives: turbo vios 1NZ-FE Join Date: Apr 2007
Well then I found it...
Thanks for doing all the work!
*Philosophy of life... Brought to you by... "Nutzoids" Nutzoids... Where Punk rock is less about Image, and more about the Mind! |
2ZZ swap's a little pricier, around $5000. But you do get 190hp from an engine that is running in spec, as well as the close ratio 6-speed gearbox
i'd love to see the 2zz swap over here.
| Just Some Things I Found | Nutzoids | DIY / Maintenance / Service | 4 | 04-03-2007 07:23 PM |
| Check what i found | Kitt | Cosmetic Modifications (Exterior/Interior) | 5 | 02-23-2007 08:56 PM |
| Found Something... Please advise! | Nutzoids | Performance Modifications | 19 | 01-15-2007 04:58 PM |
| some clips i found | esquiva | Photo-Video-Media Gallery | 3 | 09-07-2006 01:27 PM |
| found out something cool... | birdy | General Yaris / Vitz Discussion | 7 | 04-13-2006 02:05 PM |
