TPMS
Anybody have the part number for the yaris TPMS rebuild kit?
The *&&*+ at my local dealer was not very cooperative in giving out part numbers.
#2 | |
One per wheel is required.
hhmm?
#4 | |
04423-33030 is correct as well for 2nd gen.
cool
Well alright ........you are a SUPER TROOPER MY FRIEND
Many thanks Julian |
You can always just bypass the thing and just put in regular valve stems in your wheels... a whole lot cheaper.
![]() ![]() Drives: 2008 Liftback Join Date: Nov 2010
#8 | |
www.yarisworld.com/forums/showthread.php?t=11058
TPMS DIY bypass
I Saw that diy on bypassing the tpms and definitely in my future TODO list.
fyi- the part number for the rebuild kit from Toyota has changed to; 044230-E010 for those folks still looking to find the kit online or something. |
Is there a difference in TPMS & TPWS?
Is that just different auto manufacturers saying the same thing? I understand the two acronyms. Just wondering if the actual systems are different. |
#11 | |
Ours is really a warning system, as you can not actively see the info on the tires. Monitoring systems typically have the ability to display the pressure in each tire.
That's sort of what I was figuring. We aren't actually monitoring the tire pressure as much as getting a light when something is out-of-whack. Thanks for the reply. I've bookmarked your TPWS bypass DIY. If I keep these Miata wheels on (and our valve stems from the steelies can't be installed into them) I'll have to look into getting that light off in the dash. |
| TPMS questions | NEexpat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 08-02-2013 06:18 PM |
| any tpms swaps out there? steel to aluminum? | severous01 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 03-26-2011 08:10 PM |
| DIY - - -TPMS work around | rningonfumes | DIY / Maintenance / Service | 6 | 03-03-2011 09:11 PM |
| tpms compatibility? | bwong2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 07-11-2009 10:33 AM |
| TPMS Gauges - do they exist? | Sodium Duck | DIY / Maintenance / Service | 24 | 03-01-2009 01:18 AM |
