![]() Drives: 2010 Yaris Liftback 2 Dr (RED) Join Date: Oct 2012
is 08 instrument cluster compatible with 2010?
I would like to change my instrument cluster (2010 Hatchback auto) with a 2008 cluster (also hatchback auto), and wanted to know if they are compatible and plug n play. I wanted to do this because I like the white/blue color of LEDs on the 2008 better. Can I just unplug the old one and plug the new one and expect everything to work? Is there something special that needs to be done by the dealer? Are the mileage stored in the cluster or the main computer? Hopefully there's no special programming needed for it to work. Thanks in advance!
As far as I know, they can be swapped. Could be wrong though. I do know that the mileage is stored in the cluster.
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
CTScott can fix the mileage if need be. so that it is in sync with the current total or toatl at time of change.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
The 2008 will work, but you will lose your indicators for VSC, traction control, and cruise control (if you have it). Also, you would need an 08 cluster with ABS.
I can change the color, even of your 2010 to just about any color you could imagine: http://www.yarisworld.com/forums/showthread.php?t=45129
That's VERY COOL!
Now that I have a choice, I'll have to figure out what color would be best. Can it be two colors (numbers different than the lines on the speedometer)?
Any idea if you can do this for a Scion iQ? There's a display panel on the iQ that shown the time and gas level which is kind of hard to see during the day. It would be nice to be able to change the color to something more visible. I will definitely let you know on the Yaris. Thanks |
#6 | |
I haven't worked on an IQ, but I would bet that I could do it as well.
HI CTScott,
One other question... Can the 1- gas gauge/odometer, 2-the speedo, and the 3-clock be all different colors? Thanks |
Yes. That would be doable.
OK..I've decided on the colors. I think it would look good to have the main speedo in cobalt blue, the clock in red, and the gas gauge in white. Is this doable? Also, please let me know how long it would take to do it and the shipping details.
Thanks Much! |
Thanks Much! |
If you shipped me yours the cost would be $100 + return shipping. I can typically turn one back around in one day.
OK. I will try to get it out by next week and ship it to you. Please send me the address. Also, I think having the clock violet, the speedo blue (not the deep cobalt blue), and the clock, etc WHITE would be easier on the eye. I'm only more concerned with the cobalt blue being hard to see mostly at daytime, but I think the normal blue would be easier both day/night. Do you remember how many LEDs total to get them all changed?
Thanks. |
#13 | |
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
Yes! 2014 10th Anniversary Edition (new born) and 2010 Red HB/Auto. My most favorite cars!
| Instrument cluster swapout help | JudgeM | DIY / Maintenance / Service | 39 | 08-30-2025 10:19 PM |
| Willing to trade 2010 MPH liftback cluster w/tach w/ABS for cluster w/tach wo/ABS | Jabro | Willing to Buy by private party | 4 | 12-21-2012 07:34 PM |
| Sedan Instrument Cluster to LB Instrument Cluster | Malaya1221 | Cosmetic Modifications (Exterior/Interior) | 2 | 12-02-2008 11:05 PM |
| instrument cluster swap S -> LB | elo79 | Performance Modifications | 1 | 12-21-2006 11:22 AM |
