Embracing Curves
Drives: '14 Prius Executive Join Date: Aug 2013
Brake symbol turns off delayed after engine start
Hi,
I recently noticed the brake symbol turning off with a short delay when I start the engine. It's about 1...2 seconds, but no longer than PS, ABS etc. stay on. Is there an issue about to come or can I let my diag interface stay where it is?
Brake symbol should turn on and off with your handbrake.
Embracing Curves
On Yaris with ABS, the brake light is an indicator for the ebrake as well as a secondary warning light for the ABS. I found this out experimenting with clusters. If you install an ABS equipped cluster in a non-ABS Yaris the brake light stays on.
| The Yaris Performance Primer | eTiMaGo | Performance Modifications | 31 | 10-20-2025 10:08 AM |
| Engine Slow to Start | ruimond | DIY / Maintenance / Service | 26 | 04-24-2021 03:37 PM |
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 06:34 AM |
| Engine dress up - brake fluid resivoire cap? | YarisSedan | Cosmetic Modifications (Exterior/Interior) | 5 | 11-15-2008 08:59 AM |
