Old 05-15-2015, 12:42 PM   #1
mrdefensive
Drives: 2005 and 2006 scion xb
tuning for turbo
hi everyone, i am new to this forum, but was directed here for additional help.
I have an 06 Scion Xb (same motor) and am working on throwing a turbo kit on it. its a greddy kit, with emanage blue PnP piggy back. ive heard the emanage is not the easiest software to use for tuning, but i am hoping it will get me by for now. Im running larger injectors, and will be monitoring the A/F wideband, but besides emanage, what do you all use to tune your vehicles?
is AEM fic a better solution for piggy back? this thing isnt going to be insane or anything, and ill only be running 5psi boost. i just want to make sure its not leaning out under boost. any recommendations would be useful.
also, i live just outside Chicago, so if anyone is from this area and knows how to use emanage, please feel free to contact me, as i may need some help soon.
mrdefensive is offline   Reply With Quote
Old 05-15-2015, 12:55 PM   #2
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
I'm currently running the blitz supercharger at 6 PSI with the AEM FIC and 1zz injectors and it's been doing great for me.
I also used the boomslang harness for the FIC just for the sake of plug and play ease.
Black_griffin6 is offline   Reply With Quote
Old 05-15-2015, 02:51 PM   #3
KTS
KTS's Avatar
Drives: Vitz RS
is it a must with the blitz S/C kit to have timing control or does the stock ecu do a good job if you have some sort of fuel control already?
KTS is offline   Reply With Quote
Old 05-15-2015, 04:21 PM   #4
Black_griffin6
I don't think so. The blitz was designed to be a plug and play bolt on kit from what I understand.
The blitz kit comes with it's own fuel controller that you wire into the ECU and has it's own maps. It's so that you can use the lo/med/hi/off feature of the blitz's clutch on the supercharger.
Mine however had a bad clutch, so I decided to have it welded so it's always on and ditched the blitz fuel unit and used the AEM FIC.
Old 05-16-2015, 08:20 AM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Not a lot of folks here that use the emanage. The rule of thumb is to use a piggyback that local shops will support if you are in a pinch or just down right want a professional to set up in general.
Supercharged 2nz-fe VVTI tuning iwanttobeamole Forced Induction Forum 2 09-02-2012 07:30 PM
1NR-FE Performance & Tuning nickstamat Performance Modifications 20 08-31-2010 05:02 AM
Anyone need ECU tuning done on American Vehicles? Nexus1155 New England 5 06-10-2009 07:15 PM
FS: Redline tuning Hood Lift yrsdrgn Items for Sale by private party 9 11-03-2008 08:15 AM
