Old 06-19-2014, 06:13 PM   #1
ssh4327
Drives: Toyota yaris
Yaris leaking water?
I have a 2008 yaris that's leaking water from the passenger side when I drive it and the air conditioner is on. It's not a clogged pipe and it's not coming from the dashboard. I checked around and the pic is where it's coming from. Thanks for any help!
ssh4327 is offline   Reply With Quote
Old 06-19-2014, 06:31 PM   #2
That is the bottom of the fan motor. If it is leaking from there, then your condensate drain is definitely plugged. The drain hose is right under the top corner of the carpet to the left of there. Pull it out and stick something flexible up it and wiggle it around.
air conditioner, broken, fix, leak, water
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
Toyota Hybrid R Shows Its Yaris Roots MadMax General Yaris / Vitz Discussion 0 10-10-2013 07:14 PM
My 2012 Yaris review... CanIHazYarisHatch? Third Gen Yaris General Discussion 35 02-20-2012 02:03 PM
Testing water on 3 Drive Throttle Controller for Yaris (Vitz) twpanson Performance Modifications 57 10-31-2009 03:07 AM
