Old 08-08-2014, 03:16 PM   #1
tmontague
tmontague's Avatar
hood latch
I have one of those preventative questions to save me a lot of hassle down the road.
Last week my gf's 02 Echo's hood cable snapped at the latch. I was able to remove the grill and manually open the primary latch and then the secondary and pop the hood. I used a bike cable with a bolt crimped on the latch end and it now works fine again.
I decided to check out my 08 Yaris and realized that due to the change in hood/grill placement if my cable ever broke at the latch I am not too sure how I'd be able to manually open the primary latch. Has anyone had to do this before or know about a way to manually open the primary latch if needed?
Old 08-08-2014, 03:35 PM   #2
The 2nd gen would be tricky to get the hood open on if the cable snapped. You would have to get under the car and reach up to the latch. The plastic under cover might even need to be removed to get the proper view to do it.
Hood wide open birdman DIY / Maintenance / Service 7 12-02-2010 08:20 PM
C-One Replica Hood. Lets Fix this sucker! TinyGiant Cosmetic Modifications (Exterior/Interior) 56 11-10-2009 12:31 AM
Micro Image Hood Design Contest cali yaris Micro Image 209 10-04-2009 03:49 AM
Installed hood deflector, in-channel vent visors and hood seal. IsLNdbOi Cosmetic Modifications (Exterior/Interior) 16 12-20-2008 09:36 AM
Before you buy . . . check that hood! woof General Yaris / Vitz Discussion 4 12-02-2006 06:14 PM
