Old 06-24-2014, 06:55 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
Need help guys headlight won't shut off!!!!!
Weird issue I had today..did look at one previous post which didn't help . Already disconnected battery for half hour and also tapped on relays underneath the steering and still no solution.. Seems like it's stuck on on. Now I can use high beam by pulling the level but high beam by pushing the lever won't work unless it's in on ON position... I'm lost...this leaves the actual switch issue.. Thanks
So far I've done..
1. Disconnect battery atleast half hour and reconnect
2. Check h-lp/amt relay located on the engine compartment passenger side, and this does not shut off the light even when it's unplugged..
Where can I order a Headlight Bulb Rubber Boot online? JAM DIY / Maintenance / Service 2 12-08-2011 07:48 PM
calling all yaris guys , need your help please aucorium General Yaris / Vitz Discussion 15 07-07-2011 03:28 AM
LV guys! pinoypizzaboy Southwest 2 03-13-2009 03:13 AM
how it went the reunion, up load your pic guys !!!!!!! yoxx New England 0 11-24-2008 06:22 PM
