Look mum no stars!!
Best Grease to use on the belt?
Ok well after tryin so many times trying to get the 14mm bolt off the pulley, the belt is now makin a very loud squeakin noise.
The loud screeching sound is from the belt. The noise only screeches when i start the car, and the noise only goes for about 1 - 4 seconds then it goes away. And this scares the fook outa me.... What is the best grease / oil / lube to use on the belt to prevent it from makin that awful screeching noise when i turn on the engine.
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
so is this a tension issue or do you need the lubrication? I know there are sprays out there but don't know what is best. I guess I am kinding of raising another question rather than answering yours.
SPONSORED BY
![]() ![]() ![]() Drives: Polar White Hatch Join Date: Nov 2006
Don't grease anything man! The reason its squealing is because its slipping a bit.
There is a spray you can use, it sets up tacky to help keep the belt from slipping. But your best bet is to just buy a new belt and make sure you have proper tension on itt.
ChinoCharles Intake supporter. |
#4 | |
![]() ![]() ![]() ![]() Drives: 2007 Yaris Sedan "D" package Join Date: May 2006
what does grease do? make things slippy, yeah it won't squeal, it won't do anything, the pulleys will spin, and the belt won't go ahead try it... |
#5 | |
![]() ![]() ![]() ![]() Drives: Absolutely Red Liftback Join Date: Aug 2006
A little adjustment is all you need |
![]() ![]() ![]() Drives: 2007 White Toyota Yaris Type S Join Date: Dec 2006
yea that 14mm is a pain in the ass. What I found did the trick was put on a pair of gloves, grab a 14mm closed end wrench and just pull up. It works better if you make multiple hard pulls cause you will have a better chance to break it free.
Increase the tension if it's slipping but DO NOT grease the belt. If increasing the tension (don't over tension it) doesn't work, get some belt dressing. That stuff will increase the tackiness of the belt and eliminate the slipping. Overall, a new car with a new belt, proper tension is prabablty your only problem.
Look mum no stars!!
Thanks guys, the tension was put back to its normal state when i was tryin to get the pulley off.....after that the damn screechin occured. I guess i have to buy that Belt Dressing.....i sure hope that will work.
Use it sparingly, a little bit goes a long way.
Replace that worn belt.
![]() ![]() Drives: Yaris YRS Sedan Join Date: Sep 2006
DO NOT GREASE THE BELT!!!!
Replace as per d4w1 and tighten to spec. |
Look mum no stars!!
its not worn out, it doesnt need a replacement..........and i get it when you guys said "do not grease it"......as i said in my 1st post
"What is the best grease / oil / lube" to use, as i didnt know what kind of product to eliminate the screeching Edit : The belt dressing worked like a charm......thanks petersredyaris! :)
| DIY: Nonstop Tuning CR-Lite Pulley | ChinoCharles | DIY / Maintenance / Service | 121 | 02-03-2010 06:41 AM |
| Seat belt reminder warning Beep | Jord | DIY / Maintenance / Service | 28 | 04-09-2009 09:37 AM |
| ZPI pulley installed! | PetersRedYaris | DIY / Maintenance / Service | 5 | 04-10-2007 08:31 PM |
| Belt | Kitt | DIY / Maintenance / Service | 3 | 12-07-2006 12:37 AM |
