![]() ![]() ![]() Drives: 2007 red Yaris HB AT Join Date: Dec 2013
drum brakes make squeaky noise
This is my kid's 07 yaris with about 70,000 miles. This is a new noise, not very loud but clearly audible (with radio off). Not when you apply brakes, but when you release them. Clearly in the rear. Recently I checked the front disk brakes and the pads had about 50% wear (unknown mileage). The brakes work fine otherwise.
I never enjoyed working on drum brakes (I did it only twice that I remember, never on this car), are they out of adjustment or something more serious? Thanks! |
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
I would suspect moisture. I would pull the drums , lube the contact points and adjust.
You can lube the contact points with a small screwdriver & avoid disassemble y. Steve |
![]() ![]() Drives: 2007 Toyota Yaris LB Join Date: Mar 2007
Clean the dust off the drum if you have not done it yet.
Thanks.
I'll try to find some tutorials on YouTube as I'm a bit rusty on this. |
I couldn't find a video on Yaris, but found one on older corolla and echo, should be similar. Wow, no axle nut holding the drum and no need to take bearing apart? That's easy job. Will do it soon when it stops raining.
Clean and lubricate friction points.
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 07:05 PM |
| MJ dead | 90tsi | Off-topic / Other Cars / Everything else Discussions | 28 | 06-26-2009 03:20 PM |
| Noise from the drums.... | Lafiro | General Yaris / Vitz Discussion | 18 | 05-22-2009 10:49 AM |
| Speakers make noise when engine is on | Lafiro | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 01-07-2009 09:52 PM |
| Brakes question | MeggiemobileSFLA | DIY / Maintenance / Service | 23 | 03-16-2007 06:17 PM |
