Old 08-12-2014, 02:03 AM   #1
weslowski
weslowski's Avatar
Drives: yaris
CV joint driver (left) side
I'm about to replace a broken cv joint. Does anyone have any words of wisdom before I begin. I'm only starting this because I haven't found anything online for a yaris cv joint. Is it possible that transmission fluid will leak out? I'd love any tips.
weslowski is offline   Reply With Quote
Old 08-12-2014, 06:05 AM   #2
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
The transmission side, (Axle Seal) would be where id look for a leak. But yes, once the shaft is removed the fluid will come out, then just replace the fluid.
Probably cheaper to just replace the entire shaft as a single unit.
Check out my Build thread:
Old 08-12-2014, 03:07 PM   #3
weslowski
weslowski's Avatar
Drives: yaris
Thank you and Yes I Did get a entire unit. I'm sure Toyota has some special fluid too.
Old 08-12-2014, 03:18 PM   #4
bronsin
bronsin's Avatar
How many miles did the CV joint fail? Did the boot fail?
How much for the axle?
Old 08-12-2014, 03:24 PM   #5
weslowski
weslowski's Avatar
Drives: yaris
The boot Did not just the axle. I got a refurbished for $40.00. My yaris is about 103000 miles.
Old 08-17-2014, 04:06 PM   #6
weslowski
weslowski's Avatar
Drives: yaris
Good as new. As I was doing it I replaced the atf makes the gears slot more smooth now.
Old 08-17-2014, 04:11 PM   #7
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
Was the axle nut easy to remove? That was my main difficulty the 2 times I did that DIY job (on different cars).
jack black is offline   Reply With Quote
Old 08-17-2014, 05:08 PM   #8
weslowski
weslowski's Avatar
Drives: yaris
Nope not easy. I just got a spike and hammer so I was able to hammer the nub out of the axle. with muscle and a breaker bar and wd40. On top of that I had to use a half inch socket because I broke the 3/8 socket. Pretty tight.
Driver side mirror Frank Necrosis Third Gen Yaris General Discussion 1 08-06-2013 04:23 PM
AIR BAG SENSOR FOR FRENCH MANUFACTURED VERSION OF 2005 YARIS T3 edgarinuk DIY / Maintenance / Service 7 09-11-2012 02:36 PM
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 10:20 PM
Clicking noise when jerking steering wheel side to side/hit bumps left side eii DIY / Maintenance / Service 8 03-22-2010 07:46 PM
