Old 09-29-2014, 01:37 AM   #1
maui
Drives: 2008 Yaris hatchback in white
TPMS sensors question
I am buying some OEM 5 spoke aluminum wheels. The guy removed the TPMS sensors to use on his new wheels. I have sensors on my steel OEM wheels.
Both cars are '08 hatchbacks.
It look like the tires must be taken off the rims to remove the TPMS sensors
Can someone please verify this? I assume this just takes an extra minute but please correct me if its more complicated or requires any special mechanical skills.
Thanks
maui is offline   Reply With Quote
Old 09-29-2014, 04:23 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Yes you need to remove the tires in order to reach the sensors.
I am not sure the steel wheels use the same sensor than the alloy wheels though.
Old 09-29-2014, 09:13 AM   #3
Same sensors work for both wheel types. It is recommended that you replace the seals for the sensors when moving them to new wheels.
Old 10-01-2014, 02:58 AM   #4
maui
Can I use a regular valve stem on the aluminum wheels that originally came with TPMS sensors? The hole looks a bit larger...
Old 10-01-2014, 07:33 AM   #5
Yes - Regular valve stems fit on TPMS wheels with no problem. I run a set that way.
Old 10-01-2014, 01:55 PM   #6
maui
thanks CT, is it possible to install the rubber valve without dis mounting the tire?
Old 10-01-2014, 02:02 PM   #7
Kind of. You can break the bead on that side and insert the stem in to the inside of the rim without pulling the tire off.
Are your tires mounted with no stems?
Old 10-01-2014, 02:19 PM   #8
maui
yes, they original owner dis mounted them to get the sensors for his new 18" wheels
then he had the tire put back on without a valve so I just have the holes...
Old 10-01-2014, 02:26 PM   #9
That's a bummer. I don't know why he would not have just had them slap a set of normal stems on them while the tires were off.
Old 10-01-2014, 03:18 PM   #10
IllusionX
Most likely someone told him that new TPMS valves are 150$ and said just to reinstall the tires without them instead...
TPMS Sensors... Do I need them? EPyarisdriver Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 02-04-2012 10:01 AM
FS: Yaris steel wheels with TPMS sensors ctrj Items for Sale by private party 4 11-29-2011 08:10 PM
TPMS Sensors with Toyota Alloys? Lil Abner Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 06-20-2011 12:29 PM
Help Guys!! Wheel & TPMS Question! Yaris4L1fe Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-26-2011 10:19 PM
TPMS sensors & Tire Size kosko Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 03-13-2010 12:49 PM
