Which parking lights are better?
For the sedan, which parking lights would illuminate the whole orange plastic thing the best.
The straight forward or the 360 style? Also what color? (Bright white?) Thanks in advance |
![]() Drives: 09 hb 2nzfe m Join Date: Apr 2014
i had the top 360 ones as park lights in my HB. they where nice and bright at night. i'm not sure they would have enough light output to illuminate the hole orange section and still be visible as an indicator for daytime use
for the 99c off ebay for a pair. definitely worth a few minutes to see if they work tho. |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
assuming the brightness of each of the LEDs are the same (but of course REALLY bright), then the 360 will be better.
if i may say so though, since these are parklights, Polarg amber bulbs are better. There is little point in changing to LEDs since their cosmetic advantage when blinking are offset by 1) you don't use them as blinkers and 2) their reliability may be questionable since LEDs are sensitive to heat, and our parklight integrated into the headlight doesnt help. just my 0.02. |
#4 | |
I just want some bright ones,don't have to be led |
#5 | |
For brightness you can compare ONCE you put them in. Try the forward ones and if they seem to look like a dot on the headlight as compared to lighting a bigger area, then you might be looking at 360s. No guarantees on these thoughts of mine as every seller/manufacturer might have the LED placed differently, and we all know that LEDs only have a degree of projection of light--if that makes sense. |
![]() Drives: Yaris Join Date: Oct 2014
Have you done your interior lights? The straight forward ones make for nice map lights and a 360 for the trunk. Might replace my license plate lights with a couple of 360s since I have a few left from the kit I bought.
I have done my map and license plates with the straight forward ones and they work really well, much brighter then oem. I have yet to do the trunk. I'm planning on buying a pack once I decide which one to go with so I can do everything and have extras
Forgive my ignorance what are park lights? Are they the reverse lights? Would ether of these fit any exterior lights on a 2007 Sedan?
| Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal | V70R_Blackbrick | Cosmetic Modifications (Exterior/Interior) | 26 | 11-27-2013 10:14 PM |
| No parking lights | ryufrank | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 10-06-2013 09:28 AM |
| Fog lights, or parking lights stopped working | sylvermagyk | DIY / Maintenance / Service | 4 | 03-24-2011 05:13 PM |
| Taillights, signal lights, parking lights stop working | jamal1984 | DIY / Maintenance / Service | 2 | 10-13-2010 10:17 AM |
| Has anyone tried taping into the parking lights for fog light installation (safe?) | YarisSedan | DIY / Maintenance / Service | 14 | 03-20-2010 04:49 AM |
