Old 11-12-2014, 11:50 AM   #1
GoldenMonkey93
GoldenMonkey93's Avatar
Drives: 03 Yaris
03 Yaris Dome light help
Good afternoon people 😊,
I'm a new here and it's good to be on here, shall look forward to browsing the forum 😊
Anyhow, I have a 2003 Toyota yaris 1.0, had her about 3 months now, I noticed when I first got the car that the dome light wasn't working and thought it was only the bulb, today I had to the time to investigate, I checked the bulb and it seemed fine, I also checked the fuse just in case and it was fine, so I bought a new bulb and fitted it and it still didn't work? I made a quick circuit tester with a side light bulb and conected the wires up to the bulb and then to the plug that goes into the dome bulb holder and it didn't light up? Does this mean there's a problem with the circuit somewhere? I did connect the wires up to where the bulb is held and the sidelight bulb lit up once and then went out? I know it can be a stupid mistake but I have used the switch to turn the dome light on but nothing?
I hope it all made sense and you understand what I'm talking about 😊
Cheers
GoldenMonkey93 is offline   Reply With Quote
Old 11-12-2014, 12:38 PM   #2
Do the other interior lights work?
Old 11-12-2014, 02:03 PM   #3
GoldenMonkey93
Drives: 03 Yaris
Hi mate, yh the other two at the front of the car work.
Cheers
Old 11-12-2014, 02:11 PM   #4
Cheers
They are all fed from the same circuit, so it is definitely not a blown fuse. The light blue/yellow wire should measure 12 volts and the red/white wire is grounded if a door is open or not connected (open circuit) if they are all closed. The "ON" as opposed to "DOOR" mode bypasses the door switches and makes a chassis ground connection right at the light fixtures mount.
Start with checking the voltage on the light blue/yellow wire.
Old 11-12-2014, 02:24 PM   #5
GoldenMonkey93
Drives: 03 Yaris
No worries mate it'll get Friday before I can test it now unless I can do a quick test tomorrow after work, are these light blue/ yellow wires the ones that conect to the dome light?
Old 11-12-2014, 04:28 PM   #6
Correct. Those are the wires that connect to the dome light assembly.
Old 11-13-2014, 04:06 PM   #7
GoldenMonkey93
Drives: 03 Yaris
Managed to fix the light mate, was a bad connection to the bulb from the contacts, thanks for the help ��
2012 Yaris LE Check Engine Light On/Eco Light Off 2012YarisLE DIY / Maintenance / Service 1 01-22-2014 12:29 PM
08 Yaris, Passenger airbag off with seat belt light blink xiaoya DIY / Maintenance / Service 4 01-07-2014 10:53 AM
Yaris XP rear fog light issue bubu DIY / Maintenance / Service 4 12-05-2013 04:03 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-07-2012 12:37 AM
