Old 03-17-2013, 08:04 PM   #1
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
Exclamation 2NZ-FE, What would you do?
As the title asks, I just wanted to know if you guys were stuck withan automatic 2NZ-FE 3 Door Vitz what would you do?
Rules:
Selling it is out of the Question
Engine Swap is out as it is too costly
Goal:
At least 120 ps
Budget $1000 USD
Yes, I am secretly asking this to explore my own tuning options
Ryze268 is offline   Reply With Quote
Old 03-17-2013, 09:44 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I'd just do a few low cost bolt-on's like this...
...and a loud muffler.
Your car won't be fast,
but it will sound fast.
Old 03-18-2013, 03:59 PM   #3
bebeelo
ThatYarisGuy
Drives: Toyota Yaris 2012 SE
short ram intake - $80~$180
cold air intake - $150~$250
racing headers - $150~$260
axle-back exhaust - $280~$360
cat-back exhaust - $450~$550
Garm's intake manifold ~ $700
lol this is probably a +10 -15 ish hp gain with headers intake and exhaust and intake manifold.
bebeelo is offline   Reply With Quote
Old 03-18-2013, 04:53 PM   #4
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
it is a 2NZ-FE so i'm not really sure that the intake manifold will even bolt on.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Old 03-18-2013, 05:33 PM   #5
tooter
play every day
tooter's Avatar
I think it might just bolt right onto the 2NZ head...
Looking at the 2NZ FE specs showed that it's the same bore as a 1NZ with only a shorter stroke. Under the hood clearance of other components is an unknown, but could easily be determined with some careful measurements. Even that exhaust header pictured above is listed as fitting both 1.3 and 1.5 engines.
Old 03-18-2013, 07:18 PM   #6
Ryze268
Ryze268's Avatar
I'm glad I came to this site, you guys are legit =D
I have been looking around but I can't seem to find any headers, it also sounds like I should visit my local fab shop as decats are legal where I live
Old 03-18-2013, 07:49 PM   #7
Viperoni
Drives: 2005 Toyota Echo
Save up for a supercharger.
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
Old 03-20-2013, 08:57 PM   #8
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Leave it as is. It's meant to be a granny mobile. Nah.. Seems to me the common mods are ; 1zz throttle body, spacer and garms intake manifold.
Old 03-21-2013, 02:08 AM   #9
yariseggvvti
Drives: Yaris Hatchieback
Upgrade your suspension and smoke fast vehicle in to the turns. They brake in the turn and your gas exit the turn.
yariseggvvti is offline   Reply With Quote
Old 03-21-2013, 05:56 PM   #10
Ryze268
Ryze268's Avatar
Yes, definitely won't ignore the suspension and I don't see my Vitz as a 'granny mobile' =P
Old 05-01-2013, 09:03 PM   #11
Ryze268
Ryze268's Avatar
Would it be possible to stroke the 2nz to a 1.5? If possible how would I go about doing it?
Old 05-03-2013, 10:48 PM   #12
Just get 1nzfe crank/listless/rods
But just get coilovers and tires...
Old 05-03-2013, 11:18 PM   #13
Ryze268
Ryze268's Avatar
listless or pistons?
Old 11-16-2014, 08:59 PM   #14
marion2
Drives: Yaris Sedan YRS
Just get 1nzfe crank/listless(piston)/rods
Do I have to do something like balance it before installing it on my 2nz-fe engine? I mean are they interchangeable like a replacement to my previous crank , pistons, connecting rods?
marion2 is offline   Reply With Quote
Old 05-04-2013, 01:22 PM   #15
Pistons...auto correct
Old 05-12-2013, 09:19 PM   #16
Ryze268
Ryze268's Avatar
^ It's that easy? If yes I'm definitely going to do it =D
Old 05-12-2013, 10:41 PM   #17
Doesn't the NCP10 use xA/xB peripherals, like cable throttle?
Old 08-03-2013, 01:59 AM   #18
Ryze268
Ryze268's Avatar
you are indeed correct
Need Help with 2NZ ECU pinout Aleil DIY / Maintenance / Service 3 12-28-2020 09:40 AM
Using DFCO to increase your MPG BailOut Fuel Economy Forum 216 08-30-2018 04:15 AM
Turbo for 2NZ.... Centurion2200 Forced Induction Forum 9 08-25-2007 06:14 AM
