![]() Drives: yaris 2sz-fe Join Date: May 2009
Engine warning light..please help
The engine yellow/orange warning light in the dashboard on my 2005 1.3 2sz-fe went on today :-(
The car felt normal so I continued driving home. I tried to fasten the gas cap and I also disconnected the negative terminal on the battery to see if the warning light did a reset. It didn't :-(...I noticed that the radiator fan started when I turned the ignition to on (without starting), so i let the engine cool off and gave it another try.The same thing happened, the radiator fan began spinning. It turned off and on with an interval go about a minute, even though the engine was cold. I have a had a minor leak around the water pump for some time, but has not been a problem and I always kept the coolant reservoir full... Any ideas? Thanks |
first, find out what the code is. Second, get your WP fixed. The code may be something as simple as a sensor gone bad
Thanks..let's hope it's a broken sensor
Sent from my iPad using Tapatalk HD |
DIYer
Drives: yaris 1.5 MT Join Date: Oct 2014
i believe that your coolant temp sensor has gone bad, its designed in a way that the fan would be on 100% of the time if the sensor failed, instead of 0%.
Thanks...do you know where the coolant temp sensor is located?
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
| engine light on | Foxy | DIY / Maintenance / Service | 3 | 08-24-2014 03:31 PM |
| 2SZ-FE custom air intake check engine light | JDM::RSTLESS | DIY / Maintenance / Service | 8 | 08-17-2014 11:42 AM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| Check engine light flashes during high reving | AlphaFox | DIY / Maintenance / Service | 40 | 08-21-2007 01:43 PM |
