Old 12-28-2014, 04:39 PM   #1
CoryM
Drives: 2009 5-door, 5-speed
Limited slip differential options
Hey guys.
Just trying to get a post (sticky?) that has all options for LSD in it. I'm not an expert, so will need help. Part numbers would be great
-Kaaz clutch type 1,1.5,2 way.
-Cusco clutch type
-OS Giken clutch type
-Quaife helical
-TRD helical(obsolete but used available.)
-OE helical from JDM (I don't know anything about these. Same as TRD? Which vehicle have them?)
-OBX helical (do they even make one for the Yaris?)
Not going to include Phantom Grip as they are not proper LSD.
Any additions (companies, part numbers, options, required fluids) and corrections would be great.
Thanks.
Cory
Just going to add a tag for "torsen" in case someone is searching.
Old 12-28-2014, 05:46 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
There's a few options for Quaife, based on which gearbox/engine you have:
1.5 L 1NZ-FE > QDF15E
1.8 L 2ZR-FE > QDF21E
Both of these units are 8-bolt, but the 21E uses the larger output shafts of the 1.8 L model, and has a different shoulder diameter for the front ring gear. If you have a 1.5 L, you need the 15E.
Old 01-01-2015, 01:49 PM   #3
CoryM
I guess that means one needs to be careful getting a used helical from JDM or EU. Good info. Thanks.
Old 12-31-2014, 10:21 AM   #4
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I'am running the Kaaz and... I love it! Don't know why I waited so long to buy it ��
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 01-11-2015, 11:45 PM   #5
marion2
Drives: Yaris Sedan YRS
If the LSD for a 1nz-fe would still be able to fit on a 2nz-fe or will I need some modification's, if so how or is it possible?
marion2 is offline   Reply With Quote
Old 01-11-2015, 11:55 PM   #6
I believe that your 2NZ-FE Yaris over there is paired with the C54 transmission. If that is the case, then you require a different LSD than what is used with the C50 for the 1NZ-FE.
WTB: Limited Slip Differential FHT_Racing Willing to Buy by private party 0 10-10-2014 05:23 PM
KAAZ Limited Slip Differential Compatibility sheekeebut Performance Modifications 11 07-25-2014 12:18 AM
fog light options charleschia1986 Cosmetic Modifications (Exterior/Interior) 3 11-13-2009 05:00 PM
TRD limited slip: part number? cali yaris Performance Modifications 9 08-13-2009 02:29 AM
Limited Slip regal Performance Modifications 13 03-20-2009 10:16 PM
