![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
How much to lower?
Wheels:16x7/4x100mm offset 40
2007 2DR HB. I was thinking 1.5 drop. Roads are good in my parts.I kind of have an obsession of missing every bump,manhole cover etc for some reason already on stock.Mind you I have always done this with all of my cars. |
1.5 inches in the rear is pretty standard. you can go a lot more if you want to. :)
Lowering
I am going the cheapest route.I am just getting other springs.I dont drive aggressivly at all but just want less wheel well showing with the wheel specs I posted
Tire BTW are 205/45R16 Comp TA 2 Here is springs I had in mind. http://www.odparts.ca/catalog/ksport...32-p-7026.html |
#4 | |
Sent from my HTC One A9 using Tapatalk |
lowering
Well I already have rims and tires in the dimensions that I mentioned earlier.
I can only afford springs. Basic question would this work without being a problem? 1 3/4'' drop P.S I may be able to squeeze in the sway bar into my budget if it helps? |
#6 | |
The struts are 2 1/2 years old.I have receipts and my mechanic said they are not original.
If struts having high kilometers on them being the deciding factor then I will go ahead and do the springs. Thanks for reply back. |
Go for it, takes about 2.5 hrs for the whole job to lower ur car than u will need alignment done to fix toe set.
springs
I will let a shop do it for me.
I do have the tools besides the spring tensioner which I could rent but I dont have proper place to do the job. I will ask my regular mechanis what he would charge. |
Like Exiwolfman, I'm on the Tein S Tech springs, but I'm still on factory shocks/struts. Loving every second of it.
springs
Well those are 1.5 and are almost double the cost of what I linked.$358.00 CAD.
Would 1.5 even make a visually noticable difference? If the ones I linked are no good then I will probaly hold off putting the new rims on this summer. |
#12 | |
1.5 makes a huge difference in visual appearance. |
#13 | |
1.5
So 1.5 drop with the wheels and tire sizes I posted/mentioned would look okay.(2 DR HB)
As long as it does not have too much gap then I may go 1.5 and go for the tein spring afterall.If a few things go as planned I can swing it in my budget. |
#15 | |
Go low or go home lol Sent from my HTC One A9 using Tapatalk |
![]() There is mine on teins Sent from my HTC One A9 using Tapatalk |
Fwiw 1.5" drop is more than noticeable. It made a huge difference in the appearance of my yaris.
Imo lower than that gives you the "wheels tucked in" look which I didn't want as it's not my thing and I wanted function over form. Also the car sits lower with a driver in it than what you'll see when you're standing beside it so take that into account. The springs will also settle after a few months of driving and will sit slightly lower
#18 | |
Have any side pics. |
| Lower alternator bolt won't go back in, help! | Tmblackflag | DIY / Maintenance / Service | 3 | 01-21-2013 04:18 PM |
| Lower control arm replacement 2005 Echo ? | Infinitrium | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-27-2012 04:23 PM |
| Should I lower the PSI during the Winter? | paulyd0021 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 12-10-2009 11:12 PM |
| Should I lower the PSI during the Winter? | paulyd0021 | General Yaris / Vitz Discussion | 5 | 12-10-2009 07:49 PM |
