Old 01-29-2015, 09:59 AM   #1
caaront
Drives: 2007 Yaris sedan, red
Had to pull roof rack seals off, are they just cosmetic?
They were dried up and flopping about.
I figure if anything they were allowing water underneath them and the water would sit there.
Without them the water is exposed to the sun and also flows down the front or back of the car.
As far as I can tell they are cosmetic.
Is it crucial to replace them asap?
caaront is offline   Reply With Quote
Old 01-29-2015, 06:02 PM   #2
caaront
Talked to a tech, will be fine. Admin can delete.
Old 01-29-2015, 07:38 PM   #3
The seams under there are just glued with a few spot welds. I would replace them to protect the seam sealer from breaking down with the UV.
Old 01-29-2015, 09:37 PM   #4
caaront
Thank you.
Old 01-29-2015, 10:04 PM   #5
Yaristeve
Drives: 3-door hatch
Just wondering if you could repeat what the tech told you.
I am always looking to stabilize my Yaris on the freeway (still looking to stick on vortex generators) But I was also wondering if taking the flat seals off and replacing them with tall air dams (about 2" or more? talll) might help keep air from "spilling over" the sides and help car track straight?
Old 01-29-2015, 10:20 PM   #6
caaront
Said there is no need to rush to put new ones on.
That was about it.
OEM roof rack mounting rubber pad replacement Yai Cosmetic Modifications (Exterior/Interior) 3 12-22-2012 01:01 PM
Catastrophic Yakima Roof Rack Failure Kaykogi General Yaris / Vitz Discussion 8 08-14-2012 04:59 PM
Yaris 2 door Hatchback Thule roof rack question dasnake Cosmetic Modifications (Exterior/Interior) 5 03-22-2012 01:15 PM
Another roof rack option for Yaris! Cosworth General Yaris / Vitz Discussion 6 08-07-2011 11:29 PM
Roof rack question? Mister Z Cosmetic Modifications (Exterior/Interior) 11 04-21-2011 10:17 PM
