Old 11-20-2017, 11:19 AM   #1
Pinchlite
Drives: 2007 yaris HB
Key buttons wont lock/unlock doors.....
(EDIT UPDATE)
Fixed thanks to Mickman.For future reference step 5 could cause the procedure to work or fail.I tried with 3 times on/off and that did the trick,it may be 1 or 2 on/off's for others though.
Yarisworld to the rescue again :D
I put in a brand new battery,dome lights work so no blown fuses.
The small red light on the key itself lights up when pressed.
Toyota wants $50 just to diagnose never mind fix.
Not sure what to do.Suggestions welcomed.
Old 11-20-2017, 12:54 PM   #2
Mickman
Drives: 2006 Yaris RS
Try following the reprogram procedure. I had the same problem as you, and reprogramming fixed my issue.
http://freeremoteinstructions.com/to...ris-2006-2010/
Mickman is offline   Reply With Quote
Old 11-20-2017, 12:58 PM   #3
Pinchlite
Holy!Thats quite the set of hoops to jump through.
I will give it a try and report back.
Old 11-20-2017, 01:06 PM   #4
Pinchlite
Tried it the best I could.No dice.
Looks like I will just get used to using the key the old fashioned way.Cant afford hundreds of dollars to get fixed.
Old 11-20-2017, 02:49 PM   #5
Pinchlite
Fixed!!!
Holy smokes it worked!
Step 5 was the issue.I chose 3 on/off's and then the doors locked.All is good.
Thanks for the help big time!
Old 11-20-2017, 02:56 PM   #6
Mickman
Usually I am the once receiving help from this forum..Glad I could help for once!
Old 11-20-2017, 03:04 PM   #7
Pinchlite
key
You made my day.
New remote key fob programming costica DIY / Maintenance / Service 1 04-17-2016 09:02 PM
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 07:32 PM
Lost key (transponder and remote lock/unlock) shyeoh DIY / Maintenance / Service 4 07-11-2013 06:04 AM
Yaris Key fob wont lock my doors! Treeny DIY / Maintenance / Service 3 03-29-2012 08:27 AM
lock/unlock buttons matthewai Cosmetic Modifications (Exterior/Interior) 9 01-14-2011 01:00 PM
