Old 01-24-2015, 06:53 PM   #1
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
Question Noise: Window constantly rubbing weatherstrip when closed
So after I was hit in the rear right side of my car, spinning it around, it was repaired by a body shop and it looks great. BUT I do hear something new that Ihave never heard before and its pretty annoying. Every little pebble/hump/bump/hole in the the road the car goes over causes what sounds like the window rubbing in the weatherstripping right next to my ear. Its pretty extremely annoying and constant. the only way I can get it to stop is to roll down the window a little bit.
Is this a sign of a big problem (like frame is damaged) or is there an easy fix? I thought about putting some vasalene up in there but that would probably get all over the window when I roll it down and it smears over the bottom weather seal in the door.
Would shock mount bracing front and back improve things if it is a body frame problem flexing?
DIY - OEM Power Window Conversion CTScott DIY / Maintenance / Service 29 10-28-2024 12:02 AM
Yaris Verso: Reset power window jam protection togo DIY / Maintenance / Service 3 01-10-2013 11:03 AM
Power window noise birdman DIY / Maintenance / Service 10 09-01-2012 01:11 PM
rubber rubbing noise from front right of car Golddeenoh DIY / Maintenance / Service 5 06-07-2012 07:14 PM
Rear window sedan crackling noise. krolos General Yaris / Vitz Discussion 3 04-09-2011 01:39 AM
