Old 01-29-2015, 09:40 PM   #1
caaront
Drives: 2007 Yaris sedan, red
MT makes noise in reverse
Might be normal, reminds me of the sounds the huge army trucks I used to drive used to make.
caaront is offline   Reply With Quote
Old 01-29-2015, 10:35 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
If it's a weird whining noise I believe that's normal.
Old 01-29-2015, 11:04 PM   #3
CoryM
Drives: 2009 5-door, 5-speed
Yaris use straight cut gears for reverse, and they are very loud. It's normal. The army truck probably had straight cut gears for forward gears as well because they are stronger )and cheaper ;) ).
Cheers.
Old 01-30-2015, 08:14 AM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
Straight gears...
http://youtu.be/dmweKvFtg2c
Old 01-30-2015, 08:26 AM   #5
caaront
Good.
Old 01-30-2015, 08:26 AM   #6
caaront
Thats it.
Rattle - Noise when Yaris put in Reverse Jungle Rot DIY / Maintenance / Service 14 08-27-2015 07:32 AM
Grinding noise in 1st and reverse spookybathtub DIY / Maintenance / Service 0 01-24-2015 09:21 PM
Grinding noise in reverse NickNickNick DIY / Maintenance / Service 14 03-15-2013 04:10 AM
Help With Reverse Noise???? JoshW DIY / Maintenance / Service 0 09-09-2011 01:27 PM
2007 LB Auto-Trans NOISE in Reverse Pavel Olavich General Yaris / Vitz Discussion 4 03-22-2007 08:42 PM
