![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
How do these spark plugs look to you ?
Had them changed out at Toyota service center while in for suspension work . Replaced with DENSO SK16R11 plugs at $8.99 each . Car was idling rough , so had them replaced , seems no better . The tech lost one of the nuts for the engine cover and will likely have to order one at $2.35 . Here are pictures of used plugs at NGK , http://www.ngksparkplugs.com/tech_su...qs/faqread.asp . Which one looks close to these ? Don't look that healthy to us .
Mr. 155 and climbing
I needed to replace the nuts myself a few times. I just purchased them at local hardware with the correct thread and have done fine. NO worrying about ordering any. Just a thought.
Those plugs don't look bad for 73K miles.
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
I like how ash fouled and worn are the same image....
Sent from my C6902 using Xparent Skyblue Tapatalk 2
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... |
#6 | |
Thanks , but I expect to get it back the way it went in with all the parts . It's less than $2.50 . They're going to try to locate it , if not , hopefully a new one through parts .
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
seafoam
looks like a candidate for a Seafoam cleaning at the Intake manifold. Did wonders for my 200k mile new beetle.
Seafoam ...does really work ? I did my plugs at aground 140km and they looked clean nothing like urs ....also did u clean ur throttle body mine was dirty would stick and caused bad ideal , easy to do just make sure u have key on and someone on the throttle pedal when cleaning or ur get we'll May engine light .
Sent from my iPhone using Tapatalk |
![]() ![]() ![]() Drives: 2007 red Yaris HB AT Join Date: Dec 2013
Little wear but lots of carbon. Any oil consumption? Is this short trip driving? If so, this car needs some hwy driving or Italian tuneup.
Like Scott said with over 70k the results are not bad per se. Personally I would verify after 15-20k more miles how new ones look just for due diligence sake.
From my m-o-b-i-l-e
No oil consumption . Usually 50 or more miles per drive on urban roads , interstate and some city . Did use some Chevron Techron for the tank before removal of the NGK and install of the new Denso , probably around 300 miles of driving of Techron on the NGK .
More pics of NGK the plugs .
#14 |
They are OK. Just gap them and put them back in for another 200,000k miles.
#15 |
#16 |
Yes , these are the NGK IFR5A11 installed at the factory .
#17 |
Got the nut in the mail and put it on . The car is still idling a bit rough . Oh well
#18 |
Have you cleaned the TB and checked the engine mounts?
| Location of Spark Plugs | KEVBD | DIY / Maintenance / Service | 7 | 02-03-2012 12:05 PM |
| Laser plugs? - Awesome | Altitude | Off-topic / Other Cars / Everything else Discussions | 1 | 04-24-2011 09:02 PM |
| article on spark plugs and the fit | kngrsll | Performance Modifications | 4 | 08-02-2009 12:50 AM |
| did autolite spark plugs screw up coil or coils ?? | la_scanner | DIY / Maintenance / Service | 20 | 04-09-2009 03:07 PM |
| Upgraded Spark Plugs For Boost | whooppee777 | Forced Induction Forum | 9 | 02-14-2009 02:53 PM |
