Old 03-05-2015, 08:43 PM   #1
yaris0985
Drives: yaris sedan 09
How to fix p2138-yaris
I have code this code 1-2x Time winter....
After looking fews post yarisworld i not sure about the problem
Tps/ tb / pedal sensor.....
I have Only 1code p2138
Start with change the pedal sensor+cleaning the tb ???
An suggestion
Yaris 2008 automatic 1nf-ze
Thank
yaris0985 is offline   Reply With Quote
Old 03-05-2015, 09:40 PM   #2
P2138 is specifically for the pedal circuit, so cleaning the throttle body will not help. Besides the pedal, the ECM could also be the culprit. I would check the ECM connectors for corrosion, but more likely the issue is with the pedal.
Old 03-06-2015, 10:45 AM   #3
yaris0985
Thank Ctscott
The choice now is pedal sensor or the pedal
What do you suggest
Old 03-06-2015, 02:39 PM   #4
The pedal sensor is part of the pedal assembly.
Old 03-06-2015, 06:26 PM   #5
yaris0985
Thank my mecanic Guy remove a antitheft wich was plug directly on the pedal the throttle answer a 100x Times better but now i lose the Cruise control....(rostra)
I return monday to see him to get this fix....i hope
Old 03-06-2015, 10:45 PM   #6
Ah - The Rostra cruise control systems were recalled in Canada and you are not the first to have one fail where it effects the throttle position sensor data.
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 04:13 AM
