Old 03-04-2015, 01:49 AM   #1
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Find wire that shows ground when car is armed.
I need a source that is switched ground when car is armed. I would tap the aftermarket alarm "ground when armed" but it doesn't appear to work.
Check out my Build thread:
Old 03-04-2015, 07:50 AM   #2
Grab the blue wire on pin 21 of connector D33 of the main body ECU (which is the connector on the back side of the under dash fuse panel).
Old 03-04-2015, 06:56 PM   #3
ezhacker1
ezhacker1's Avatar
Is this the connector im looking for?
or
This?
I cant even reach back there to feel the connectors.
Old 03-04-2015, 07:10 PM   #4
I see one connector behind the fuse panel. But isnt that one above.
The picture is not displaying. But, if you go up the back side of the under dash fuse panel, there is one connector just above the label on it.
Old 03-04-2015, 07:34 PM   #5
ezhacker1
ezhacker1's Avatar
I see this connector.
Old 03-04-2015, 07:40 PM   #6
No. it is physically on the back of the box way at the top. You have to reach/look about 8" above where you are.
Old 03-04-2015, 09:32 PM   #7
ezhacker1
ezhacker1's Avatar
I feel one plug, way at the top. So little room or slack to work with even to unplug.
Old 03-04-2015, 09:46 PM   #8
You can also grab it at the driver's kick panel. The blue wire next to the green unlock wire.
Old 03-05-2015, 03:58 AM   #9
ezhacker1
ezhacker1's Avatar
I used the blue wire, next to the green door unlock. Opposite outcome of what i need.
It might help if i say what im using it for. Im installing DEI 516L (Voice System) One wire from its harness, says when grounded and kept grounded makes the system say (arm and be prepared for any door/sensor violations) and when it doesnt see ground it says (disarm)
Right now, when i arm my alarm by remote it says (disarm) and vice versa. Even more annoying is even using the physical door lock buttons, or even manually locking the door, it speaks, and the voice system is "armed" and ready to look for door violations.
Old 03-05-2015, 08:12 AM   #10
OK. The service manual describes that wire as being grounded when locked (there is no actual armed output on the Yaris). So, in that case, to use the wire you would have to invert its output.
Old 03-05-2015, 11:07 PM   #11
ezhacker1
ezhacker1's Avatar
Odd that it is showing grounded when unlock instead.
Old 03-05-2015, 11:44 PM   #12
I just read it wrong when I looked at it quick. There is nothing I can find with the correct polarity. If you want, I can make you a special version of the device that I use for the Scion IQ hatch switch mod to do the inversion for you. You'd be looking at about $15 shipped for it.
Old 03-06-2015, 03:01 AM   #13
ezhacker1
ezhacker1's Avatar
Cool workaround. But looks like the module would arm, even when im locking the doors with the switch. Can something be made to use the lock/unlock wires to show ground/no ground respectively.
Im not sure why the after car alarm's "ground when armed wire" for the starter killer isnt working.
Old 03-06-2015, 07:24 AM   #14
What wire were you told is the GWA wire?
My module does use the lock/unlock wires to make the GWA signal. The problem with those wires is that they are pulsed, not held, so you would just get the signal for a second and then it would go away.
Old 03-07-2015, 04:38 AM   #15
ezhacker1
ezhacker1's Avatar
the manual for the car alarm that i have says that particular wire is Ground when Armed.
Yup, i first tried the lock wire, and noticed it is pulsed when instead i need held, or it'll say arm then disarm real quick.
Old 03-07-2015, 09:22 AM   #16
It looks like my module might be the best option. It's too bad that the alarm doesn't have the option of having that input reversed (+ when armed).
Found this 2014 Mitsubishi Mirage ES yesterday Hershey Off-topic / Other Cars / Everything else Discussions 97 01-30-2014 12:30 PM
Testosterone: The New Synthetic Oil bronsin Off-topic / Other Cars / Everything else Discussions 23 12-15-2013 07:02 PM
Yaris In Forza 3 whooppee777 Off-topic / Other Cars / Everything else Discussions 61 04-03-2010 05:36 PM
CtrlAltDefeat - Photo-Scavenger Hunt CtrlAltDefeat Photo-Video-Media Gallery 0 03-04-2009 03:14 AM
