Old 02-11-2015, 07:02 PM   #1
spookybathtub
Drives: 2007 Yaris HB
Ambient temperature sensor OBD-II data
I've read the Yaris has an ambient temperature sensor in the front bumper. Is there any way to access that information? I have a PLX Kiwi Wifi with DashCommand app, but it shows temperature is not a supported metric.
spookybathtub is offline   Reply With Quote
Old 02-11-2015, 07:23 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
The sensor is for the duty cycle of the AC. Apparently,there is another one at the condenser, to prevent freezing.
Old 02-11-2015, 08:14 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Yup....doubt that you would be able to access that with anything but the TechStream from Toyota.
Old 02-11-2015, 08:35 PM   #4
It can only be read by talking to the AC ECU, so normal OBDII PIDs for ambient temp don't work.
Old 02-21-2015, 10:32 PM   #5
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
You can only access that information with Techstream.
JudgeM is offline   Reply With Quote
Old 02-22-2015, 06:02 AM   #6
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
Nope, If I remember correctly I had been able to read it out using Torque, the right header and the right PID.
I don't remember it exactly, but I took it from a PID set for a Prius of the 2nd gen I think.
I drive, therefore I am.
dj92 is offline   Reply With Quote
Old 02-22-2015, 07:08 AM   #7
IllusionX
We are talking about a yaris here. The Prius have an ambient temp sensor.
Old 02-22-2015, 09:37 AM   #8
So does the Yaris. I display the ambient temperature on my YarGauge (homemade diagnostic tool), but you have to talk to the AC ECU to get the data, rather than to the ECM (so it is not a standard OBDII PID, but rather a manufacturer specific diagnostic PID).
Old 02-22-2015, 11:29 PM   #9
IllusionX
Does that mean Toyota uses the same sensor, and get the info from the AC ECU in some cars?
Old 02-23-2015, 06:07 AM   #10
Yes. But, some (including the 2010+ Yaris) pass that data to the ECM, so that it can report it with a standard OBDII PID.
Old 02-22-2015, 08:53 PM   #11
dragoonmc
Drives: 07 hatchback
Ctscott is it possible to set this up on a Scangauge 2?
dragoonmc is offline   Reply With Quote
Old 02-22-2015, 10:22 PM   #12
Possibly.
Old 02-24-2015, 09:20 AM   #13
dragoonmc
Ctscott please post the pid you used to get the info from the Ac ecu.
Old 02-25-2015, 10:03 PM   #14
2122 is the command, sent to address 07C4.
Old 03-23-2015, 07:58 AM   #15
flgLtd
Drives: 09 Yaris
Do you know if the '09 is different than a '10 in this respect? I just replaced my '10 with an '09 and I can't seem to get the Amb temp on my Scan Gauge II anymore???
flgLtd is offline   Reply With Quote
Old 03-23-2015, 12:21 PM   #16
As I said in post 12 above - The 2010 and newer Yaris supports it. No prior years do.
Debunking fuel conservation myths... nmgolfer Fuel Economy Forum 144 10-28-2010 09:51 PM
Water temperature Bob_VT General Yaris / Vitz Discussion 11 11-03-2008 03:17 PM
ambient map lighting? atebit Cosmetic Modifications (Exterior/Interior) 0 11-05-2006 01:15 AM
