Old 04-03-2015, 10:21 PM   #1
gumby002
Drives: 2008 Yaris Hatchback
Reese Hitch
I purchased a Reese Hitch 77191
It is NOT a perfect fit. I will need longer bolts for the upper bolt placement or i will need to start cutting of the hitch itself.....am i doing something wrong?
You can see by the scrapping on the (2) humps where the hitch is hitting them.
2008 Hatchback.
gumby002 is offline   Reply With Quote
Old 04-03-2015, 11:14 PM   #2
Compare the hole to hole measurements on the hitch and car. You might have gotten one that was assembled incorrectly.
Old 04-04-2015, 01:14 PM   #3
gumby002
CTScott, very hard to measure, but I did bolt the bottom enough to get it to hold while I put a smaller screw through the top hole to check alignment. It fits. the issue is that the welded bracket is not cut right and it hitting the humps in the above pic.
Old 04-04-2015, 01:18 PM   #4
gumby002
Looks almost like it needs a spacer.
Old 04-04-2015, 06:20 PM   #5
You wouldn't want a space there. I would either just notch it with an angle grinder, or return it for one that fits. I installed a Curt hitch on my 09 liftback and it was a very quick and painless install.
Old 04-04-2015, 07:36 PM   #6
gumby002
So.....it fit, I just need a little hand from someone who had a great deal more experience and patience than i.
Genuine Toyota Hitch for Yaris now available in Canada voodoo22 DIY / Maintenance / Service 8 04-22-2014 08:50 AM
2013 Yaris SE - Hitch Issues? bm_cricket Third Gen Yaris General Discussion 8 06-16-2013 10:51 PM
Draw-Tite Hitch Install Sodium Duck DIY / Maintenance / Service 35 11-12-2012 06:36 PM
Where to buy and install a Hitch?? molinee Cosmetic Modifications (Exterior/Interior) 9 12-29-2011 06:13 PM
New Hitch Installed fmicle DIY / Maintenance / Service 26 05-25-2010 03:25 PM
