Drives: 2008 Yaris Sedan Join Date: Apr 2015
Brake adjuster loosening while driving?
Hello,
I've had brake issues with my 2008 Yaris sedan for a few years now. Last two times I've taken it in to a shop. Problem is with the adjuster on the right side drum. Rather than self-adjusting it is self-loosening. I've had the adjuster replaced 3 times with new aftermarket parts. Problem persists. Not sure what else to try. Any suggestions? I do not want to keep trowing money at this problem. This is the vehicle my wife uses to get to work and take our daughter to kindergarden. I need a permanent fix. Do not want to risk our family's life. Thanks, Martin Last edited by mnieves79; 04-11-2015 at 10:33 AM. |
maybe you're putting the adjuster in the wrong way. one way will self tighten the other will loosen....if it can be backwards.
Toyota Lover
Drives: 2009 Toyota Yaris Sedan Join Date: Apr 2015
You likely have a problem with the adjuster arm incorrectly installed or adjuster incorrectly installed. do a search to get an image of the rear-brake assembly to verify it yourself.
'09 Flint Mica Sedan 345,000km and counting
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 09:50 AM |
| The brake story: frequent disk warpage | Lux | DIY / Maintenance / Service | 20 | 11-01-2014 01:25 PM |
| Front brake caliper pins | DarkSkyGhost | DIY / Maintenance / Service | 7 | 06-10-2014 09:05 AM |
| Drum brake problem. | theb | DIY / Maintenance / Service | 4 | 04-23-2014 03:04 AM |
| DIY For radios that require attaching a wire to parking brake | Slick | DIY / Maintenance / Service | 0 | 04-16-2009 09:14 PM |
