Old 03-27-2015, 02:54 PM   #1
Supra_Yaris
Logan
Drives: 2009 Yaris Liftback Base MT
Do I need Spacers?
I will be running 15x7.5 rims with 30mm offset. Will spacers help handling? I will also be adding -1.5 degrees camber up from and -3 in the back. I want my rims and tires to poke out a little.
Supra_Yaris is offline   Reply With Quote
Old 03-27-2015, 10:11 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
This should be interesting post pics cos u gone need camber to make it work right and why spacers just go with 20 offset... Sounds like ur looking for stance look not so much how it handles.
Old 03-27-2015, 10:42 PM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I run the same setup. Are you putting on Konig Candy's? Thats the ones I have on my sig.
I have 205/50 tires with -2.8 camber up front and stock in the back. barely rubs the fenders, but it does. Just enough to take the letters off the sidewall.
-Derrick-
Old 03-27-2015, 10:43 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Can you post pics of your ride ...please.
Old 03-28-2015, 10:39 AM   #5
ilikerice
ilikerice's Avatar
Post 21 in this thread
http://www.yarisworld.com/forums/sho...t=32516&page=2
I was on 195/55 on that one. I will try and get some pictures today of my ride. I still haven't swapped out to my Daily Drivers yet so I can snap a couple pictures today
-Derrick-
Old 03-28-2015, 11:01 AM   #6
Supra_Yaris
Logan
That looks good. That is more the look I am going for. I currently have 195/60 that I will swap over until I need new tires. I was reading through your thread and I could not find anything about your suspension. How did you lower your car, and by how much?
Old 03-28-2015, 10:18 AM   #7
Supra_Yaris
Logan
Yes I am putting Konig Candys. How much are you lowered?
Old 03-28-2015, 06:22 AM   #8
WorkTL
WorkTL's Avatar
Drives: 2013 Yaris LE
15x7.5 30+ is pretty weak if you want to run flush.
I will be running 15x8 -13mm front and -0mm rear on 155/60R15.
The rear wheels sink in more than the fronts, so run more -mm offset spacers in rear.
WorkTL is offline   Reply With Quote
Old 03-28-2015, 10:59 AM   #9
Supra_Yaris
Logan
Which specific wheels will you be running?
Old 03-29-2015, 11:38 AM   #10
WorkTL
WorkTL's Avatar
SSR mk III, 3 piece wheels.
Old 03-28-2015, 04:37 PM   #11
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
I hope you meant 15x8 +13 in front.
I wouldn't recommend going with skinnier tires (155?!)
But if you prefer it then at least go 175 if you're aiming for a stretched appearance.
Old 03-29-2015, 11:40 AM   #12
WorkTL
WorkTL's Avatar
Yes, I meant +13.
Im running 175's now it's barley a stretch.
I run 245/35 on an 11" rear on my other car...that's a nice stretch. :)
Old 03-28-2015, 11:44 AM   #13
ilikerice
ilikerice's Avatar
Sorry, i couldnt tell you how much, but i am on Megan coil overs. If i were to guess, i think it was lowered 3 inches
-Derrick-
Old 03-29-2015, 04:37 PM   #14
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Yeah, 175 isn't must of a stretch for 15x8 but you should also remember that you still want some tire to keep you planted to the road.
Skinny tires are fine but you'll have a fun time with your steering wheel on the freeway!
I didn't have 15x8+13 to compare but here is my old setup for a stretch reference.
Nice choice on SSRs! :)
Old 03-29-2015, 05:18 PM   #15
WorkTL
WorkTL's Avatar
Looks perfect. Thanks for posting those pics.
I'll be running 155/60R15 on mine.
Old 03-30-2015, 05:19 AM   #16
ilikerice
ilikerice's Avatar
Sorry wasn't able to get this uploaded yesterday.
205/50/15 on Konig Candy's wrapped BFGoodrich Rivals
-Derrick-
Old 04-17-2015, 12:56 AM   #17
Ben_
Drives: 2010 Yaris Hatch
As far as handling is concerned I wouldn't think having the tires farther out would do much. If anything I would say more unsprung weight = bad and worse handling. If it doesn't rub I wouldn't run spacers as far as performance is concerned
Ben_ is offline   Reply With Quote
Wheel spacers walkthrough :) Lars Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 06-05-2014 09:49 AM
Hood Spacers. First Ever on YarisWorld! 1.5 Photo-Video-Media Gallery 58 12-04-2012 09:45 AM
Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed RedVitz Photo-Video-Media Gallery 18 10-09-2010 04:36 PM
question on Rear Hub Spacers mastaofdisasta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 02-02-2010 10:54 AM
Installed 10mm PG spacers on a 15x7 +25 wheel kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-27-2009 08:10 PM
