Old 04-24-2015, 02:45 PM   #1
RWJC
Drives: 2014 Yaris LE hatch
2014 LE hatchback
Hey all, 1st post, and glad to be here.
I have an issue with the low beam being used for the DRL. I can either unplug the DRL relay, but would prefer to switch it to the parking light (orange one) Any tips on how to make this happen??
Thanks in advance all!
RWJC is offline   Reply With Quote
Old 04-24-2015, 04:33 PM   #2
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
These types of posts are like a Bat Signal to CT Scott...he's the resident engineering guru and should be able to help...
Old 04-25-2015, 11:33 AM   #3
RWJC
I am wondering if it would not be in the steering column by the relay for the DRL??
Old 04-28-2015, 02:10 PM   #4
RWJC
CTScott, any ideas Sir??
Old 04-28-2015, 02:23 PM   #5
I am in Germany on business and don't have the wiring diagrams with me.
Old 05-02-2015, 11:23 AM   #6
RWJC
ok, have a safe trip..see ya when you get back..
Old 05-03-2015, 12:42 PM   #7
Looking at the wiring diagrams for the 2012+ liftback, the DRL is far more integrated than it was for the 2nd gen Yaris.
For the 3rd gen the body ECU commands the module via the green wire. The DRL module is the direct output to the low beams, so pulling the module would eliminate low beams (unless you then jumped the black wire in pin 1 and the red wire in pin 5 to the black wire in pin 6 to bypass it).
If you really want to drive something else as the DRLs I would recommend trying the snipping of the green wire and if indeed that turns off the DRLs, then I would feed the other thing chosen as DRL from an ignition switched power feed.
Old 05-06-2015, 12:37 PM   #8
RWJC
Thanks CT, may try that this wknd. I'll reply back when I have completed it!
Old 05-09-2015, 06:49 PM   #9
RWJC
Wheel package
OK, so I have not yet gotten around to the wiring, but I needed tires. He had some 16 & 17", but they were not a good fit/look for what I wanted. I did find some 18s that with a 215-35/18 on them were almost dead on with the stock size. I have full clearance, no offset needed, and looks good.
Old 05-10-2015, 11:16 PM   #10
RWJC
added CAI
COST FROM PEPBOY'S, CUSTOM MADE $87
seat of the pant test, good gain in pickup an hp, MPG improved.
Using a Spectre Cone filter, 6.5"w x 7.5"l
removed all stock parts except oil breather line & MAF sensor which is new.
Removed battery for 5 min to reset ECM.
Check engine light will come on if I rev it sitting still, but as of now, has not done while driving. The throttle mech seems to be almost completely electric..??
MAYBE TOO much air??
Old 05-11-2015, 12:30 AM   #11
RWJC
leak check in the morning..
Old 05-11-2015, 02:08 AM   #12
LTHatch
Drives: 2013 Yaris Hatchback L
What size MAF tube did you get? Possibly i am mistaken but did you say you bought a new MAF? From the threads on here, too large a MAF tube will throw a code, that's possibly what's causing yours.
LTHatch is offline   Reply With Quote
Old 05-11-2015, 10:54 AM   #13
Thebigwicks
Drives: 2008 lowered yaris on 17's
I just saw you pass by the Giles dealership in Lafayette! So cool to see another Yaris world member in LA!
Thebigwicks is offline   Reply With Quote
Old 05-11-2015, 11:03 AM   #14
Thebigwicks
Sorry for the unrelated post!
Old 05-11-2015, 11:24 AM   #15
ern-diz
ern-diz's Avatar
I'm not a big fan of chrome on these cars, but your wheels look sharp.
Old 05-11-2015, 07:59 PM   #16
RWJC
3" vs a 2.5 in I think...
Old 05-11-2015, 08:00 PM   #17
RWJC
Sweet man, may have to meet up and grab burgers one day...let me know.
Old 05-11-2015, 08:13 PM   #18
RWJC
updated setup and pic...
Mi nuevo Yaris 1.3 Hatchback (2014) guillermoguerreroz Central and South America 11 10-06-2015 05:18 PM
Eyeing a new 2014 SE hatchback... MidnaFan New YARIS Purchase Forum 19 06-24-2014 12:26 PM
new 2014 hatchback le pugdaddy Third Gen Yaris General Discussion 8 04-29-2014 11:52 PM
2014 Mazda 3 Kal-El Off-topic / Other Cars / Everything else Discussions 32 11-08-2013 01:51 PM
