Old 04-21-2015, 07:21 PM   #1
tdinut
Drives: 2008 Yaris Sedan Auto
Coming up on 135K miles, anything I should do to my car? ...
Hi Everyone,
My 2008 Yaris is coming up on 135K miles. I think it's time for a new battery and maybe a muffler, but what else should I be thinking about?
New hoses?
I have time for new trans fluid. What else do you guys think? Plugs were done a little while ago. Car runs really good.
Joe
tdinut is offline   Reply With Quote
Old 04-21-2015, 09:05 PM   #2
tmontague
tmontague's Avatar
most of the things you mentioned generally do not need to be replaced unless they are broken/damaged. Mufflers tend to last longer than that and my '02 Echo still has all of the original hoses on it and they're in great shape and still very pliable. I would do some of the following, or at least inspect:
-control arms bolts L&R
-coolant change
-trans fluid
-inspect the shocks/struts for leaking, see how they're handling
-Clean PCV valve
-Spray some corrosion protector on all of the exposed bolts underneath the car.
-Replace upper exhaust gasket (the one just below the head)
-Your alternator has a metal male bolt sticking out of it just above the connector. Cover that in dielectric grease and reconnect the wire. It will save you from having to replace the alternator down the road because it rusted and snapped (ask me how I know)
-change your serpentine belt
Can't think of anything else at the moment
Old 04-21-2015, 09:45 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
The muffler, while it is made of stainless steel, the pipe that is directly behind the muffler is not. Mine has rusted through at the last hanger and made a hole on the pipe.
Old 04-22-2015, 07:09 AM   #4
bronsin
bronsin's Avatar
I put my car up on ramps twice a year and crawl around under it looking for problems.
I dont change the auto trans fluid in my vehicles. Id change the MT oil per the manaul if I had one.
In general consult the OM and follow what it says to do. They know more about the car than anyone else.
Old 04-22-2015, 10:46 PM   #5
tdinut
Thank you everyone. All great info. I appreciate the guidance.
Joe
enobmort42 - Photo-Scavenger Hunt! enobmort42 Photo-Video-Media Gallery 9 03-05-2009 11:52 PM
KCALB SIRAY - Photo Scavenger Hunt KCALB SIRAY Photo-Video-Media Gallery 5 03-02-2009 11:44 AM
Custom Lftback - Photo-Scavenger Hunt custom Lftback Photo-Video-Media Gallery 2 03-02-2009 12:12 AM
Black Yaris - Photo-Scavenger Hunt Black Yaris Photo-Video-Media Gallery 2 03-01-2009 05:13 PM
