![]() ![]() Drives: 09 Yaris Join Date: Jul 2010
Anyone on 15 x 8 with 185 tires?
As title asks, is anyone running 15 x 8 wheels with 185/60 tires? Curious if someone had any experience running them.
![]() ![]() ![]() ![]() Drives: 08 BB LB Join Date: Dec 2008
tyrestretch.com is your friend.
Too much of car culture is people taking things too seriously and not enjoying it for what it is. |
Already frequent it. I was looking more if there were any fitment issues on the Yaris. :)
![]() Drives: 2k7 Yaris Join Date: Nov 2013
Fitment is really gonna depend on offset, camber, and whether or not your fenders are rolled.
![]() ![]() ![]() Drives: 09 Blizzard Pearl RS LB Join Date: Sep 2009
A 185/60 profile tire may be too high for a 8" wide wheel if you are looking for wheel clearance and achieving the "stanced" look. The stretch will almost be unnoticeable.
Are you on stock or aftermarket suspension?
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna |
![]() I'm pretty sure the owner of this Yaris is on here. But 185 will stretch onto 8" wheels. The 60mm sidewall would be an issue but I'm only lowered on Tanabe df210 springs. So I shouldn't have issues with rubbing as in sitting now. Once I wear out these wheels I will be getting shorter wall on my next set and lowering it further. The wheels I have coming Saturday are 15x8 +25. Should poke around 2" farther out from the stock steelies. I'll post pictures. Pretty certain it'll be clear. Sent from my iPhone using Tapatalk
Logan
Drives: 2009 Yaris Liftback Base MT Join Date: Jan 2015
Keep us updated on how this goes. I am also looking at getting some 15x8s and I am lowered on Df210s as well. I have 195/60s on the stock wheels now that I will be transferring over.
Will do. I may be getting them on tomorrow. I'll post up if it happens.
![]() ![]() ![]() Drives: Twin-charged rotary V8 w/nos Join Date: Nov 2011
185/50 should be fine. On 185/60, as FreeStyle stated, your stretch will be barely noticeable. With DF210s, you should be rubbing only on your right rear tire. But again, that is with +25 offset. I'm currently running 195/50 on my 15x8 +25 setup. Rubbing the right rear well pretty hard on uneven pavement.
My SSR mk III 15x8 finally arrived from Japan. Im going with 155 60R15 tires. 175 55 R15 was a "ok" stretch.
0 offset rear, +13 front. -4° camber rear, -3.5° front. |
155!!!!
I will post pics as soon as tires arrive and get mounted. :)
#14 |
![]() Confirmed it fits! I heard rubbing once on a. Slow hard right. Other than that nothing ![]() Sent from my iPhone using Tapatalk
#15 |
![]() ![]() ![]() Drives: Toyota Yaris 2009; 1.0 3 Cil. Join Date: Oct 2010
Hey Tadakun... thats me! But that is 185 on 7'' width :)
This is my setup now: 15x8 offset 25, 20mm spacers in the rear and 195/45/15 falken tyres ![]()
Speedbumps suck...!
#16 |
So if you put 185... itll be a little more stretched than this!
Speedbumps suck...!
#17 |
I posted up pictures already. :D I knew I saw your car around here. Sent from my iPhone using Tapatalk
#18 |
I see no stretch...
| Can you put 195 60 15 tires on 185 60 15 rims? | *MAD DOG* | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 04-04-2011 10:29 PM |
| Newly installed 15" tires feel 'weird' | kristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 04-24-2010 06:58 PM |
| 2007 Yaris bad tires | weaver615 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 03-27-2010 07:21 AM |
