Old 05-19-2015, 05:16 PM   #1
superguyerich
Drives: yaris
Unhappy Hello! couple questions/problems about my Echo's/Yaris('s?)!
Hey guys, newbie posting here, but not my first time on forums!
so, first question on my list of newbie questions
I have a Yaris 06 1.5L- It is turning over, but seems like it has no compression. The guy brought it to my paps ( autowrecker) because the engine died. the alt belt turns over, but it seems like its turning over VERY easy.
Can someone give me opinions on what they think the problem might be? We think it might be timing belt, but I dont want to Influence your thoughts ^_^
*I have now done more research, and found it they have a timing CHAIN.. so, never mind. what do you think could be causing this problem?
** ok, more updates. checked the spark, good. checked compression from the tubes, good. soooo. now what!
Second question at the moment.
Can an engine/trans from a O5 Echo manual get swapped into an 06 Yaris manual.
Thank you very much for any responses.
superguyerich is offline   Reply With Quote
Old 05-19-2015, 10:09 PM   #2
tmontague
tmontague's Avatar
I don't know the answer to your second Q but in regards to your first:
you also need to check for fuel. You can do this by disconnecting the fuel line and seeing if fuel comes out. Then when nothing is coming out of the fuel line have someone crank the engine and see if fuel comes out of the line where you disconnected it. If not then it is likely a fuel pump issue.
I'd also check your EFI relay, just swap it with another relay that is the same and see if it runs. If not than check the EFI fuses and AM2 fuse (if I remember correctly)
If all of those check out then it could be a bad or disconnected ground on your engine block. There are at least 2 on the driver side of the cylinder head. This causes my '02 Echo to crank and not start after removing the head to do some work. I'll be updating that thread later this week.
Old 05-20-2015, 07:06 AM   #3
bronsin
bronsin's Avatar
Pappy should have another engine for a YAris lying around Im thinking...
echo, thankyou, yaris
A couple road trip pics Manley81bass Photo-Video-Media Gallery 8 11-13-2010 08:46 AM
A couple pictures ... JBougie Photo-Video-Media Gallery 29 07-06-2010 10:30 AM
New guy with a couple questions! 2slow Cosmetic Modifications (Exterior/Interior) 12 05-05-2009 09:28 AM
new user with a couple of problems grant_nelton Great Lakes 8 03-13-2009 11:18 PM
Just a couple of photos from a nice day Thirty-Nine Photo-Video-Media Gallery 6 02-11-2009 10:42 AM
