![]() ![]() Drives: Black 5-Spd Sedan S Join Date: Aug 2009
Clutch shudder when setting off in 1st gear
I love this forum, just got my Yaris 900 miles ago!!!
My Yaris' clutch shudders when starting from a stop in 1st gear, and seems to mostly happen at 1500rpm. It doesn't at all seem like a 'low power' shudder, as if I were letting the clutch out at too low an RPM or something. On my last car I would be totally off of the clutch under 1000rpm, I like to put as little wear on clutches as possible, which means starting off at lower RPMs and being fully engaged relatively quickly. What RPM should I be hitting the friction point of the clutch with? The shudder is especially pronounced when I engage a little quicker than normal, and hold around 1500rpm while engaging. Is my clutch still being broken in - was it not broken in correctly - what's going on!? I've been extremely careful on the clutch over the 900 miles I've had the car. ![]() I've searched and only saw one other thread with this problem and it didn't seem to match my issue. |
wheel hop?
![]() ![]() Drives: 09 Yaris 3 DR HB Join Date: Jun 2009
i had the same problem when i got my 09. give it a little while it will go away.
Yes, mine does it both in 1st and reverse.
yeh i am at 40,000 km and its bugs the hell out of me i think in fact it is a low power shudder because the higher the rpm the less it happens
![]() ![]() Drives: 2007 LB Join Date: Jan 2009
Yeah mine does that in 1st as well. It's a 2007 with nearly 30,000. Seems worse when it's cold. I think the yaris just prefers a higher rpm roll out.
It's been 1500 miles since I posted. Problem has 'gone away' but I think it's just that I learned how to set off without causing the shuddering. I still set off at a low RPM (put the engine around 1000 rpm and hit the friction point).
I don't like to try it since it feels bad for the car, but I think quicker engaging of the clutch at higher rpms (1500rpm) causes it. It's weird I had to re-learn how to drive stick shift after driving stick for over 3 years in my previous car :) |
does it to me some, but its not the same shudder as when you don't give it enough power when starting out.
![]() ![]() ![]() ![]() Drives: Yaris YR Join Date: Oct 2008
Kinda happened to me in 1st on rare occasions, its when the clutch is released to early and there's not enough gas pedal action. Haha. Seems pretty normal from other peoples experiences.
![]() Mods: 17x7 ANZ Tazer Wheels with 215/40/17 Marangoni Tyres | AFE Air Intake System | NST Short Shifter Kit | NST Shifter Cable Bushing Kit | NST 10% Underdrive Crank Pulley | Pedders Sports Springs | Custom 2inch Cat-Back Walker Muffler with 2.5inch Xforce Twin Stainless Steel Tip | RS Side Skirts | RS Euro Spoiler | YRX Front Lip Spoiler | TRD Style Front Grill | 12mm Rear Hub Spacers | Ultra Racing 23mm Rear Sway Bar |
![]() ![]() ![]() Drives: '07 Yaris Sedan/'03 Protege Join Date: Oct 2008
I agree with a couple of other comments here, I think you are just letting out
the clutch too early and too quickly. |
Drives: yw calls me douche and racist. Join Date: Aug 2007
It happens when its cold. Then it goes away when the car starts to warm up. Its not because the clutch is being let out too early.
![]() ![]() ![]() ![]() Drives: 2009 Meteorite 3dr Join Date: Jul 2009
Touchscreen DVD Navigation - 10" Bazooka Subwoofer - Kenwood Speakers - Toyota Premium Horn set AFE Pro Dry Air Filter - modified air intake box - 1ZZ-FE Throttle Body - Ultra Racing Rear Sway Bar & Front Strut Bar NST in cabin & engine bay SSK's - TWM shifter base bushings & cable bushings - Megan Racing C-Pillar Brace |
#14 |
ya.. the DBW changes the way you sync your left foot with your right foot. You just got to get used to it.
#15 | |
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
#16 |
it sounds like clutch chatter because you're slipping it too long...
#17 |
![]() ![]() ![]() Drives: 2017 VW Jetta 1.4L Manual Join Date: Feb 2009
#18 |
Heart Up! Vitz
Drives: トヨタ Vitz Join Date: Jun 2007
For the reverse shudder, I learned slowly let out the clutch, and gas a bit more at the same time. That helps for a smooth reverse. Yeah it seems like you will be clutch burning, but very little to even make an impact....
| Help Me Find The Right Clutch | RacerFreakXXX | Performance Modifications | 18 | 10-20-2010 06:20 PM |
| 1st Gear Revs... | Masteraal | General Yaris / Vitz Discussion | 9 | 09-30-2007 11:22 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 12:34 PM |
| clicking into first gear | tekmoe | General Yaris / Vitz Discussion | 9 | 11-01-2006 03:44 AM |
