Old 09-19-2015, 12:38 PM   #1
Kdaddy81
Drives: 08 yaris sedan
Engine/Transmission mount... How?
How to replace the engine tranny mount on 08 Yaris auto sedan. I did the top pass side mount and rear tourque mount. Just got the one left...
Where is it located and about how long to swap out I'm good w cars I just like to ask and know ahead of time.
Thanks in advance
Keith
Kdaddy81 is offline   Reply With Quote
Old 09-19-2015, 06:02 PM   #2
tmontague
tmontague's Avatar
Remove the intake and battery and it's right below.
Old 09-19-2015, 07:23 PM   #3
Kdaddy81
Awesome thanks for responding
Old 09-24-2015, 04:47 PM   #4
Kdaddy81
Any tips or tricks for this mount job? I'm gonna tackle it tomorrow when my wife gets home from work.
Thanks in advance!
Old 09-24-2015, 06:38 PM   #5
KTS
KTS's Avatar
Drives: Vitz RS
To do this you don't need to raise the car I did this with my Vitz RS parked in my driveway.
Remove the intake air box - Philip screw driver and 10mm socket with and extension.
Remove battery and battery tray - 10mm and 12mm
Support the tranny - Toyota scissors jack should do just fine.
Remove the mount - about 5 14mm bolts and the 19mm bolt and nut that goes thru the mount.
It is not a difficult task. I rate it's difficulty similar to changing the out two mounts.
Approximate time is about 1hr from start to finish and less if you have done it before.
KTS is offline   Reply With Quote
Old 09-25-2015, 05:42 PM   #6
Kdaddy81
Doesn't sound bad. The hard one was the rear for me. This sounds pretty straight forward!
Thanks for replying!!!
Old 09-25-2015, 06:21 PM   #7
Kdaddy81
Should I do this mount as well after I do the driver side one and is it hard to do? The other two were not that bad..
Old 09-27-2015, 05:58 PM   #8
Kdaddy81
All done! Car doesn't make any viberation noise or clunks into gear after doing 3 mounts. Thanks for the help! Very much appericated! Really I mean that, very helpful people here.
God bless
-Keith
Polyurethane Engine Mount (not 3m) KTS Performance Modifications 0 08-24-2015 06:45 PM
Top mount or front mount intercooler vitz rs Forced Induction Forum 10 09-14-2010 06:31 AM
DIY Cellphone Car mount Arkhangel DIY / Maintenance / Service 3 08-24-2010 04:37 PM
Anyone using ProClip Angled Mount for iPhone? AliCLick In Car Entertainment + Electronics (audio / video / alarm) 7 01-21-2010 08:07 PM
DIY Camera Mount -- No Cost Version KCALB SIRAY DIY / Maintenance / Service 20 06-08-2009 04:12 PM
