Yaris Dyno charts
If you've taken your Yaris on a Dyno, post the results here, along with a list of relevant mods
![]() To start off, here's one by staticorex, bone stock.
The price of freedom of religion, or of speech, or of the press, is that we must put up with a good deal of rubbish. - Robert Jackson ![]() Bye bye 1NZ... Last edited by eTiMaGo; 11-04-2008 at 11:06 AM. |
![]() ![]() ![]() ![]() Drives: 2008 Black Sedan Join Date: Oct 2008
kool cant wait to see the results
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
Was it a manual or AT?
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
#5 | |
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2013
I definitely want coil overs and a roll bar now. Workin on switchin to 16 inch rims with Michelin Pilot Sport AS 3's next. My favorite rim choice at the moment is the 4 bolt Helium or Feather black. Thanks for the good article link/read Cali
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
![]() ![]() ![]() Drives: Black Yaris YRS 3dr Manual Join Date: Aug 2007
5400-6100 not much difference in power output lol
Here is mine with intake, header, pulleys and axle-back exhaust:
And here is mine with the turbo set up on stock motor @ 8psi,
along with a different pull from the dyno session shown before:
Parallel Parking Pro
Here's mine:
DC Header, Fujitsubo Exhaust, Denso Iridium Spark Plugs, 5W40 Shell Helix Oil. Otherwise everything is as standard factory delivered. Numbers on the chart are at the crank. WHP is roughly 102.75 and torque is 130Nm (95.8ft/lb). EDIT: Thanks for pointing out the unit difference for torque; I have added the lb/ft conversion.
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header Last edited by cleong; 11-06-2008 at 09:33 AM. |
rice rocket
Drives: 05 Echo Join Date: Feb 2007
that's because yours is measured in Nm :P everyone else is ft-lbs.
not a yaris but same engine anyways, only mods are intake and muffler replaced with a small resonator. edit: manual transmission, did all runs in 4th gear
this will be a very useful thread
+1 |
cleong, you're hp and torque don't cross at 5250 -- sup with that?
also, wouldn't the rev limiter kick in at 6250? Or do you not have the same limit as we do in USDM?
#13 | |
Your NA dyno chart seems to go to 6500rpm too. But redline's 6500rpm on my dashboard, I think. I'll need to run out and check it later.
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
#14 |
![]() ![]() ![]() ![]() Drives: 07 metmet LB Join Date: Oct 2008
Is it all dynos charts that should cross at 5250...or is that just a correct setup for our engines?
F5 CAI, MR axleback, MR Header, NST SSK. Full Exhaust wrap, AT3 Custom SSK Konig Heliums 15x6.5 Black Tanabe Df210's |
#15 | |
![]() ![]() ![]() Drives: 2008 Yaris hatch Join Date: Oct 2008
HP and tq are alwasy equal at 5252 rpm. The reaosn they don't cross on the graph is that the two scales are different. If both HP and NM (converted to tq) scales went from 0-160, then they would cross at 5252. Here is the 120-hp graph supplied previously before the hack. Mods were custom intake manifold, CAI, Xd tb, synthetic oil and off-road down pipe with no exhaust.
#16 |
Had to straight-line interpolate where the sensor had a bad connection.
Not as good as I had hoped. This was my baseline before the supercharger install.
#17 |
~ ambient one ~
Drives: 2009 Bayou Yaris Liftback Join Date: Jan 2007
Now are these all with manual transmissions?
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine ambientlifestyle.com------------ambientlifestyle.ning.com ![]() Micro Image Store - Network - Online microimageonline.com------------microimage.ning.com |
#18 |
123-Wheel HP
Here is a graph of our recent test using a CAI (actually flipped over stock filter lid), the new intake manifold, long-tube header and 2.25-inch exhaust, NST u-pulleys & Xd Tb. Might be more with additional tuning once FIC arrives from AEM for testing.
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| WR Yaris Intake Picture & Dyno. | WRLEO | Performance Modifications | 37 | 04-05-2007 07:02 PM |
| WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! | WRLEO | Sponsors Classifieds Area | 0 | 02-22-2007 10:14 AM |
