Old 07-11-2015, 11:04 PM   #1
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
What Walbro pump
For the boosted guys, what Walbro pump are you using? I'm looking to upgrade but I'm not sure what pump fits and what needs to be done to install it.
2014 BSpec Divisional Champion
Old 07-17-2015, 11:29 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I think most go with the 255, but that's way overkill unless you're making big power. I think the 190 is the better option.
My knowledge is only from memory of what I've read
Old 07-19-2015, 12:59 AM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I am using an AEM 320LPH. Deatchwerks makes a 300 as well. I skipped the Walboro route.
Sent from my SCH-I545 using Tapatalk
Old 07-19-2015, 01:01 AM   #4
fnkngrv
fnkngrv's Avatar
The 190 is more expensive hence the reason why so many go with the 255. According to an engineer I spoke with at Walboro he said the 190 could easily support up to 350whp in our application. He said going bigger would reduce efficiency as the returned fuel will be heated up during transit prior to obviously being sent back to the tank.
Fuel filter replacement jaimico DIY / Maintenance / Service 43 03-07-2023 11:05 AM
Cannot fill gas at a pump dinoman DIY / Maintenance / Service 38 08-13-2014 01:50 PM
Car shuts off when A/C turned on... Howster DIY / Maintenance / Service 33 07-06-2013 05:00 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
